Old 11-10-10, 10:05 PM   #1
pce13
Default Sticking Throttle
Im having trouble with my SV650S 2000, the past two weeks when i first get on the bike in the morning the throttle stick open it returns almost every time but revs its **** off pulling off at 8000rpm is not fun any ideas what the problem maybe? Its fine when the bikes warmed up though!!
Thanks in advance for help and advice
Old 12-10-10, 09:00 AM   #2
bigchris
Mine was doing this, strip the throttle cables out and use a cable oiler to flush and lube the cables.
While your under the tank give all the carb linkages a lube.
Once you have ruled out sticky cables check cable routing and tension as per haynes manual.
Mine used to be fine once warm and i think it was the heat from the engine loosening whatever crap was sticking the cables.
Old 12-10-10, 09:05 AM   #3
warrenhewitt10
Default Re: Sticking Throttle
if its the cable sticking you probably need a new one just, I read that oiling them etc isnt good in the long run, However I dont understand this 8k rpm thing, do you rev it that much then let go and it stays there, or does it go to 8 on its own?
Old 12-10-10, 06:45 PM   #4
pce13
i will check cables at the weekend, @ 8000rpm, i ride off and when i turn off the expressway the engine is still doing 8000 rpm when im pulling off from the junction, whatever rpm im doing on expressway it stayed at ever when physically throttled off
Old 13-10-10, 12:57 PM   #5
embee
embee's Avatar
Sounds like you haven't got a throttle return cable on it. You should be able to manually override the spring return system by rolling the twistgrip forward.
The 2 cables work as push/pull, one opens the throttle and the other closes it, it's done as a safety system in case return springs break or it all gets sticky for some reason.
Throttle sticking. bigchris SV Talk, Tuning & Tweaking 3 16-08-10 10:42 AM
Heated Grips, throttle sticking. newts924 SV Talk, Tuning & Tweaking 9 22-02-10 09:32 PM
Sticking throttle sv_rory SV Talk, Tuning & Tweaking 5 18-02-09 01:13 PM
Throttle / Revs sticking (and now brake question) goof SV Talk, Tuning & Tweaking 15 12-06-06 09:54 AM
Throttle sticking/stiffening KayDee SV Talk, Tuning & Tweaking 1 14-05-06 12:44 PM
