Old 16-10-10, 01:47 PM   #1
DavieSV
DavieSV's Avatar
Default New top yoke, GSXR front end.
I needed a top yoke for the 750 forks,
So this morning I went to work, found some aluminium and set to work...
It's not quite finished but the trial fitting looks good.
I just need to machine the clamps and get it finished in some way.
Next onto the speedo fix.
DavieSV is offline   Reply With Quote
Old 16-10-10, 01:49 PM   #2
Wow that is brilliant. Looks really good.
You should start a business
Old 16-10-10, 01:53 PM   #3
xXBADGERXx
Default Re: Top Yoke
How is it clamping onto the fork legs ?
Old 16-10-10, 01:53 PM   #4
DavieSV
DavieSV's Avatar
Johns-Yokes
Old 16-10-10, 01:54 PM   #5
xXBADGERXx
Or do the clip-ons clamp to the legs then the clip-ons bolt to the yoke ?
Old 16-10-10, 01:54 PM   #6
DavieSV
DavieSV's Avatar
I'm going to split the inside of the fork collar and drill & tap from the front.
Old 16-10-10, 01:55 PM   #7
DavieSV
DavieSV's Avatar
and yes, the clipons bolt to the under side of the yoke
Old 16-10-10, 01:55 PM   #8
xXBADGERXx
Oh I see , drill in from behind/front near the milled out triangle
Old 16-10-10, 02:02 PM   #9
DavieSV
DavieSV's Avatar
Like this
Old 16-10-10, 02:05 PM   #10
xXBADGERXx
Split it on the inside and then drill and tap through , maybe mill out a larger diameter so you can hide a cap head in there . I would also Mill it out from the ignition side to keep it tidy looking
GSXR K4/5 Top Yoke BillyC For Sale - Other Bikes and General biking items 0 05-09-10 11:05 PM
gsxr 600, 750 top yoke k6 or k7 stamasman Stuff Wanted 0 26-08-10 09:42 PM
GSXR top yoke nut CheGuevara Stuff Wanted 8 15-06-09 07:23 PM
Y - K3 Gsxr 750 top yoke drag Stuff Wanted 0 10-06-09 09:49 AM
GSXR Front Wheel and Upper Yoke CheGuevara Stuff Wanted 0 15-05-09 09:27 PM
