Old 13-11-10, 12:25 AM   #1
Elltg
Default Curvy SV Water Pump Drive?
How is the water pump driven on an 01 model curvy sv650? As far as i can make out from the ron ayers exploded view here it seems to be driven off some type of gear inside the engine. Is this correct? That it is driven off the engine?
I am just interested in it at the moment i have a small leak between the o ring and the clutch cover so i am looking at the whole area am im going to be taking it apart soon (new o ring on order).
Whilst im at it i dont suppose anyone could shed light on a mystery spare connector my bike appears to have? I will get a picture at some stage but will post a description now in case it is well recognised.
It is located in front of the carbs but behind the headstock of the frame. It is a 2 pin connector with say 5-7mm thick black cables it is quick release with keyed holes one square one circle. The interesting thing is there appears to be 2 of one end. I cant remember which way round it is but i either have two males and one female or two females and one male, each with wires routed into the bike. (will try to follow them when i get pictures)
edit: forgot common courtesy! Any help is greatly appreciated!
Old 13-11-10, 11:22 AM   #2
Default Re: Curvy SV Water Pump Drive?
Yes. The primary drive gear, (on the end of the crank - drives the clutch basket), also carries a smaller gear which drives the water pump.
Are you referring to the plastic clutch outer cover? If yes then the right side casing does not need to be removes to replace its 'O' ring.
Ermmm... No, not a clue. Could guess at heated grips connector, or... Something else. Pictures are the way forward!
You're welcome.
Old 13-11-10, 01:30 PM   #3
Elltg
Brill. My only experience with pumps is DC driven pumps for computer water cooling, was wondering why my pump appeared not to have any leads!!
I was a bit unclear there. I meant its leaking out of the side of the seal that seals the water pump to the clutch cover.
I think you are bang on the money, this bike did have heated grips when I got it and those exact wires were used. I thought I had eliminated them. May have to remember that to source some power some day!
You're welcome.
Well thanks again!
Old 13-11-10, 01:33 PM   #4
Is the water pump drive leaking or is it the more common clutch cover leak?
Clutch cover can get warped over time, so you may need a new cover, not just a new O ring.
Plenty of threads about this, do a search
Old 13-11-10, 02:10 PM   #5
Elltg
Hi, I'm not trying to flame or anything. I have searched and searched and decided my first step will be to change that o ring. If it does not solve my problem I can take it from there.
Whilst I have the water pump housing off I can have a proper explore around the area and hopefully I will see any possible problems.
Old 13-11-10, 02:47 PM   #6
http://forums.sv650.org/search.php?searchid=3296956
List of threads relating to clutch cover leaks
Old 13-11-10, 02:56 PM   #7
embee
embee's Avatar
Just a throw away thing here, considering the clutch cover O-ring crops up regularly.
I don't know how much Suzuki charge for the clutch cover O-ring, I bet it's not cheap.
I recently needed 2 different size O-rings for Kawasaki oil coolers and for about the cost of those 2 pieces I got 15 of each in a suitable material (NBR) from http://www.polymax.co.uk/
They gave the efficient service you hope for these days from internet suppliers.
If anyone knows the exact size and section of the clutch cover rings it would be viable to do a group buy for anyone wanting a spare. You could even try a thicker section if it's a practical proposition (groove dimensions allowing). Note that O-rings are dimensioned as cross section diameter of the rubber and the INSIDE diameter of the ring. For face sealing you usually size them to be a slight interference fit in the outside diameter of the groove (about 1% typically IIRC) so they are in very slight compression in the groove.
As a guess, I put in 155dia x 3mm NBR rings in the basket and with postage and VAT it works out at £17 for 25 rings, that's 68p each. Pop in an envelope and a stamp, a bit over a quid a piece to orgers. Just a thought.
Suzuki price?
Old 13-11-10, 04:16 PM   #8
Originally Posted by embee View Post
Suzuki price?
£15m
Good post though, why pay dealer prices for a item that is exactly the same, which you can buy elsewhere for sensible money
Old 13-11-10, 05:57 PM   #9
Elltg
Guys just to say, it is the water pump o ring I am replacing. Also it is the water pump housing that is leaking.
PS your search link comes up with nothing anyway? I guess the searches expire.
Got the o ring ( pictured as part 8, part no 17418-19F00 >> O RING) for £3.60 with £3 p+p !
Curvy Water pump SVDragRacer Stuff Wanted 2 22-03-09 11:58 AM
Cover for the Water Pump - Curvy Demonz Stuff Wanted 4 15-10-08 07:44 PM
205 pugi DTi water pump... Richie Idle Banter 2 01-12-07 04:46 PM
water pump casing for 99 650 Styler Stuff Wanted 2 02-07-07 03:51 PM
Removing water pump neuone SV Talk, Tuning & Tweaking 5 08-02-06 01:39 PM
