Old 17-11-10, 07:17 PM   #1
lh25
Unhappy Speedo reads double.
hi have just replaced my speedo drive unit and now it reads twice the speed im actually doing i was following a car at 39mph mine was saying 80mph any ideas how this is happening or a fix for this please
cheers
Old 17-11-10, 07:28 PM   #2
Default Re: speedo reading
is it a pointy or curvy?
I would check the connections are in properly and ok
after that I have to say get it checked or use a speedo healer
Old 17-11-10, 07:29 PM   #3
lh25
its a curvy y reg
Old 17-11-10, 07:32 PM   #4
danf1234
That means a curvy can do 200mph - Anyone wanna but a pointy!
Old 17-11-10, 07:37 PM   #5
Check the connections first
You completely remove the old drive? sounds like a daft question but a double the speed (actual vs indicated) reading would indicate that the sensor is getting double the amount of pulses it should be
Old 17-11-10, 11:00 PM   #6
hongman
I thought this was something to do with the magnets, vaguely remembering other threads on identical issue.
Old 17-11-10, 11:19 PM   #7
You used wrong rotor... change it for one from an >04 bike... K5> has 8 pulses per rev instead of 4.
Old 18-11-10, 07:13 AM   #8
lh25
oh right cheers well would it work if i used the matching pick up as i have it ???
Old 18-11-10, 02:36 PM   #9
fastdruid
fastdruid's Avatar
Default Re: Speedo reads double.
No.
Druid
Old 18-11-10, 03:34 PM   #10
Owenski
What you should defo do, is strap a camera to your bike where the speed is shown in shot, ride on a road with 40mph limit doing an indicated 80mph then post the vid on you tube. Could be amusing.
Speedo reads erratically. bengrrr SV Talk, Tuning & Tweaking 9 08-06-10 08:07 PM
Speedo reads wrongly. I'm_a_Newbie SV Talk, Tuning & Tweaking 5 30-04-10 05:04 PM
Speedo reads wrong. Suzi SV650 SV Talk, Tuning & Tweaking 6 26-04-10 06:54 PM
Seeing double - speedo svrash SV Talk, Tuning & Tweaking 6 17-01-08 10:28 PM
help speedo reads twice as fast? sv650hellspawn SV Talk, Tuning & Tweaking 1 17-04-06 02:41 PM
