Old 23-11-10, 11:07 PM   #1
jambo
jambo's Avatar
Lightbulb Careful when setting off, things might be broken...
This is probably teaching most people to suck eggs, but I had an experience this week which I thought would be worth highlighting.
Whenever I set off on the bike I tend to have a little routine to check everything is as it should be. I know what the bike was like yesterday, but hey, you never know, something could have changed right?
Check of oil & chain lube, then I back the bike out of it's space by foot, checking for dragging brakes / flat tyres as I go. I pull the clutch in and out, twist the throttle, and start the bike, I then tend to give the brakes a little squeeze and then head off slowly. I accelerate & brake gently for the first couple of sets of lights then build up pace. This lets the bike warm up before it gets any grief and means my head's straight before I do anything too silly.
On Monday I did the above and set off, as I braked gently to the first set of lights the front brakes bit nicely, then the lever travelled a little further than normal. I stopped and squeezed the lever again, good feel, followed by lever travel. I look for the leak and see fluid escaping from the front right caliper banjo.
No biggie, I'm only a few yards from the house. Turns out a copper washer had seemingly failed. Looked OK when removed, and I had a spare, but even though the banjo bolt was tight fluid was escaping. The caliper's not been disturbed for about 3 weeks since I did the pads, and that bolt's not been undone for a year. So why it should have started to leak on Monday I'm not sure.
So just a little reminder to everyone. Keep on top of your maintenance and don't go hacking off at a rate of knots until you're sure all is well with the bike and rider.
Be safe
Jambo
Old 24-11-10, 04:22 PM   #2
davepreston
Default Re: Careful when setting off, things might be broken...
dam you foiled my evil plan
i get you jambo and your little toto too muhahahahahahahahaha
Old 24-11-10, 08:57 PM   #3
jambo
jambo's Avatar
Just because you're paranoid, it doesn't mean they're not out to get you...
Startrek.steve broken, SV650 broken too startrek.steve Bikes - Talk & Issues 31 26-08-08 12:49 PM
Be careful please Bluepete Idle Banter 5 01-01-08 12:00 PM
Broken dreams and broken lives. Peter Henry Idle Banter 7 15-09-06 07:43 AM
be careful now! Shinsei Jutsu SELKENT 2 30-03-05 01:16 PM
be careful Iansv The Essex Lounge 3 04-03-05 05:07 PM
