Old 26-11-10, 10:30 PM   #1
g13unisol
Default Chain and sprockets for fast road and track?
Ive been riding for just over a year now and have an sv650 sport sk8. I have done a few track days and am thinking about upgrading my chain and sprocket set. Planing to do loads of track days in the new year just wanted some advice on the best set to get for that type of riding.
Old 27-11-10, 10:26 AM   #2
NedSVS
Default Re: Chain and sprockets for fast road and track
I wouldn't bother changing until your original chain is worn out and definately not until the spring if you are doing any winter riding. The standard chains are high quality. When you do replace just make sure you use a qulity brand - I'm a DID fan myself but I'm sure you will get other recomendations from the forum.
Old 27-11-10, 11:21 AM   #3
As Ned no point until its needed.
But a racing chain is not suited to prolonged road use as there is no washers like in a O ring and X ring chain.
Again everyone has preference, mine DID as thats whats on the bike atm.
Old 27-11-10, 09:42 PM   #4
barwel1992
Default Re: Chain and sprockets for fast road and track?
i like what im running now, tsubaki chain, renthal super light front sprocket and a supersprox rear lighter than stock as will last just as long
Old 27-11-10, 09:56 PM   #5
Teejayexc
"Polished chain adjusters" - where ?
Old 27-11-10, 10:14 PM   #6
fizzwheel
fizzwheel's Avatar
What do you think that upgrading is going to give you ? As per the others if your chain and sprocket isnt worn out then I wouldnt bother to replace them.
Unless you want to change the gearing ?
IMHO if you havent already, you'd be better off looking at some suspension work ( front forks maybe a rear shock ) that will give you bigger rewards than bolting a set of shiney bling sprockets onto your bike.
Old 27-11-10, 11:32 PM   #7
hardhat_harry
520 conversion with heavy Duty chain (not X or O ring) one tooth off the front is my preference for most tracks but others prefer 2 off the back. If your using heavy duty chain on the road you need to keep care of it but I have used them in the past on the road.
Heavy duty chains are cheaper than x / o ring chain Iris do a good gold one.
Both 520 and using standard chain will give you a little more horsepower to the rear wheel due to less rolling resistance, less weight and more direct connection due to having no o / x rollers.
B+C do a renthal superlight 520 14 tooth front sprocket for the SV but its not listed in their SV bits just ring them and ask (I think its a GSXR item)
Old 28-11-10, 12:57 AM   #8
barwel1992
lol they sort of corrode so have to polish them up
Old 28-11-10, 01:12 AM   #9
Typhoon
I have an unused 520 pitch racing chain and sprocket set if anyone is interested.
Old 28-11-10, 08:28 AM   #10
Aint 520 pitch easier to snap if not properly adjusted? (To clarify SV's use a 525 pitch chain stock)
You tried running a HD/ Race chain on the road, I thought they siezied up with road crap?
Renthal do a ultra light 14T for the 520, and I 525's I'm not to sure. Barwel runs a ultralight so should be able to clarify
Chain and sprockets sunshine SV Talk, Tuning & Tweaking 6 01-03-10 10:38 PM
New chain and Sprockets. ThEGr33k Bikes - Talk & Issues 19 21-08-08 11:15 AM
Chain&Sprockets stevie SV Talk, Tuning & Tweaking 4 23-08-07 07:10 AM
Best way to fit chain and sprockets? Captain Nemo SV Talk, Tuning & Tweaking 1 07-04-06 12:32 PM
NEW chain n sprockets sd1cko SV Talk, Tuning & Tweaking 16 09-09-05 08:01 AM
