Old 27-11-10, 10:58 AM   #1
bris
Default CBF500 wont start
Just tried to start the 2008 CBF500 for the first time in about 3 months and it wont start. Turns over good but doesn't even try to start. I took the spark plugs out and tested for a spark which was good on both plugs so getting a spark. The fuel is getting out the tank but now I'm stuck any ideas what to check now.
Old 27-11-10, 11:04 AM   #2
Default Re: CBF500 wont start
Gummed up fuel in the carbs, drain it off and fill it with fresh fuel might work, other wise you'll need to strip the carbs down
Old 27-11-10, 11:27 AM   #3
bris
Thanks for the quick reply. Is there an easy way to drain the carbs without stripping everything down.
Found a couple of drain screws so drained of the fuel.
Old 27-11-10, 11:45 AM   #4
bris
Still not trying to start will need to strip the carbs. Is this easy to do and is it easy to clean out. Thanks.
Old 27-11-10, 12:02 PM   #5
Get some carb cleaner or clean petrol to disolve to old petrol.
Before you do take carbs off, make sure petrol is getting to carbs, will save a lot of work.
Is there plenty of fuel in the tank, does the fuel get to the carbs, or is the filter blocked?
Old 27-11-10, 12:51 PM   #6
Mavi im sure the 2008 CBF's are FI
CB's were Carby's
EDIT: I'm a tool, it beat the emission rule changes (that pushed FI as the standard) and is a Carby
Old 27-11-10, 03:06 PM   #7
CB's were Carby's
You had me worried there
Old 27-11-10, 08:28 PM   #8
bris
Fuel is getting to the carbs, bit stuck now though as getting the carbs out is next to impossible. Looks like on this bike you need to take quite a bit apart to free them.
Is there no additives out there that will dissolve the gunk.
Old 27-11-10, 08:37 PM   #9
Buy some carb cleaner. See suggestions here
http://answers.yahoo.com/question/in...6164435AAcaysM
Old 27-11-10, 08:48 PM   #10
-Ralph-
How long have you turned it over on the starter motor for?
My SV wont start. Damian SV Talk, Tuning & Tweaking 16 09-03-10 08:44 PM
Car wont start sauluk Idle Banter 11 10-01-10 11:24 PM
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
Boo! It wont start. bulldoggy SV Talk, Tuning & Tweaking 14 28-03-06 05:27 PM
