Old 30-11-10, 06:11 PM   #1
barwel1992
Default electrics help - work much confused :D
ok so got some work to do for college but im a little lost can some on confirm this for me
ok so scenario: have a 12v parallel circuit no resistors and grounded to the chassis with 2 100w bulbs wired in parallel.
so my understand is both bulbs get 12v, i need to work out the amps for the diagram so 100w/12v= 8.33amp's for each wire going to the bulb. The wire that comes from the battery's + then later on splits off to the two bulbs +'s would be double that of each wire going to the bulbs because its supplying both bulbs ?
and the resistance for each 100w bulb is 12v/8.33amp = 1.44ohms ?
i truly hate electrics ......
thanks for any help if a diagram would help i can make one up
Old 30-11-10, 06:41 PM   #2
beabert
Default Re: electrics help - work much confused :D
Im not sure i understand what your question is lol, then again i am tired.
Old 30-11-10, 06:46 PM   #3
tigersaw
tigersaw's Avatar
Each lamp consuming 8.33 Amps.
Total consumption is twice that as its a parallel circuit of two lamps.
Resistance of lamps.. tricky, as they are non linear devices. But in the circumstances you describe you can assume they behave similar to a resistor of 1.44 ohms
Old 30-11-10, 07:08 PM   #4
timwilky
timwilky's Avatar
I am not going to do it for you but instead tell you what you need to do.
You need to work out the resistance of the circuit, that is the two resisters in parallel
Then the current for the total circuit can be established from good old V=IR
Do it publish it and I will tell you if you are right.
Not Grumpy, opinionated.
Old 30-11-10, 07:45 PM   #5
21QUEST
21QUEST's Avatar
What tigersaw said ie you are correct.
But timwilky has got the right idea
Nemo me impune lacessit.
Old 30-11-10, 07:57 PM   #6
21QUEST
21QUEST's Avatar
Re timwilky's post, a little pointer
V/R x V=W .
Do that for each...
Old 30-11-10, 08:42 PM   #7
timwilky
timwilky's Avatar
OK guys I will do it for him, my way
He has already worked out the resistance of a lamp as 1.44 ohms
Total resistance of parallel resistors bulbs = 1/((1/1.44) +(1/1.44)) =0.72 ohms
12/0.72 = 16.66..A
Old 30-11-10, 08:46 PM   #8
barwel1992
ok so i think this is right ps sorry bout the drawing/image paint for you
EDIT beaten to it by Tim
Old 30-11-10, 08:55 PM   #9
timwilky
timwilky's Avatar
That is the most weird diagram I have ever seen, definitely not how to wire a parallel set of bulbs back to earth.
Your current would remain constant over the circuit, you do not have different sections at different current.
Your total resistance on a parallel circuit is the reciprocal of the sum of the recipricals of the parallel resistances. So 0.72 ohms.
Old 30-11-10, 08:57 PM   #10
21QUEST
21QUEST's Avatar
Hi mate,
Mine would have been slightly different/simpler diagram .
Total resistance is wrong though(refer to timwilky's last post). You've calcilated it as as you would for resistors in series.
I'm a bit confused about whether my SV is a K1 or K2 apple tango SV Talk, Tuning & Tweaking 16 12-06-09 03:41 PM
Confused! suzsv650 Bikes - Talk & Issues 5 27-05-08 12:16 PM
Im confused !!! BLACKFIRE BSB & WSB 9 13-04-08 02:10 PM
Confused.com Rocket Idle Banter 8 24-03-07 12:47 AM
Confused!Where do I go? Whitty Pennine Massive 5 14-06-06 09:14 AM
