Hi, what is the sv bore (liner) material ?
Likely cast iron or steel
just found it on twf, must have over looked it, its steel
Holy crap dude, what do you do that you can fit bussa pistons in a 650?
You must have access to a savage machine shop and garage. Fair play, looking forward to hearing how you get on ![]() |
#5 | |
basicly you get the busa piston, fit sv rings, hone cylinder to give 0.055-0.065mm of clearance between the cylinder and busa piston fit piston using busa pin and circlips and jobs a gudden i will have 2 busa pistons available soon if your interested |
Are compression height and valve cut outs the same? Does it change the CR?
yes yes and no not really
you can split the base gasket (i think or head) and take the middle out to increase compression ps they are 17g lighter each and forged instead of cast like the sv ones |
SV 650 Big Bore kits? | liam_j_harris | SV Talk, Tuning & Tweaking | 107 | 16-05-08 06:04 AM |
bore da! | conwyrichie | Idle Banter | 33 | 06-04-08 02:24 PM |
Who can fit a big bore kit? | The Laughing Assassin | SV Talk, Tuning & Tweaking | 1 | 15-02-08 07:42 PM |
Bore out for an SV650 | danf1234 | SV Talk, Tuning & Tweaking | 6 | 22-07-07 06:42 PM |
Big Bore Kit | NSR Mike | SV Talk, Tuning & Tweaking | 17 | 06-06-05 08:50 PM |
