Sorry I wouldnt be asking this question if some numbnuts hadnt misplaced his haynes manual
![]() My fuel warning light hasnt worked for donkeys years and finally got round to looking at it today. When I turn the ignition on the fuel light is on and when I fire the bike up it goes off as it should. So took all the gubbins off the back of the clocks and got to this ![]() Left to right is high beam bulb, neutral light, fuel light and indicator light. If it works when I turn the ignition on it can't be the bulb right? I've checked all the wiring and connectors and all are fine so must be the fuel sensor yes? Have I missed anything? Ta
______________________________ |
What bikes it on?
You checked the connections at the tank side?
Curvy naked
![]() Yeah lifted the tank and traced all the wiring, everything seems ok
errm
Get new copy of the Haynes, proceed to batter yourself over the head with it. Then... Drain the tank and get the tap out and have a look at it and check the terminals etc.. I'd look at the dash connector maybe full of rust. The fuel level ones are on the 10 pin connector (4up 6down) and the fuel pins are specifically are (both bottom row) 3rd from right (Flashing) and end on right (fumes- solid right)
Haynes manual found
![]() Drained the tank, mostly on to me ![]() Thanks for the help Mr Smith ![]()
My fuel warning light is lying!! | XmisterIS | SV Talk, Tuning & Tweaking | 40 | 22-05-09 01:25 PM |
Fuel warning light, when? | lazymanc | SV Talk, Tuning & Tweaking | 10 | 02-07-08 06:35 PM |
Fuel light warning | rob13 | SV Talk, Tuning & Tweaking | 11 | 13-08-07 12:57 PM |
gas light?(that'll be fuel warning light) | Spanish Fly | SV Talk, Tuning & Tweaking | 9 | 08-06-07 05:45 PM |
Fuel warning light | Mark_h | SV Talk, Tuning & Tweaking | 8 | 24-05-07 09:14 PM |
