17-12-10, 10:45 AM | #1 |
Bar end weight removal?
Anyone got ideas on how to get the bolts out other than drilling? The phillips head on both are totally rounded.
17-12-10, 10:55 AM | #2 |
Re: bar end weights
I'm not sure if you meant to include this in 'drilling' but screw extractors are the way to go.
I had one of my bar ends snapped off leaving just threads flush to the surface at the end of the bar. I got a set of screw extractors similar to this (link) but with a t handle for around 5 pounds on ebay. Made the job easy. You drill a small pilot hole for it to thread to and then because of the way it is reverse threaded when you screw it counter clockwise it self taps itself into the screw. You keep turning it counter clockwise and eventually it wont thread any further and because you are still turning counter clockwise you end up undo-ing the screw. The beauty is of course it is all the time keeping the pressure on making sure it is getting as much of a grip on the screw as possible. Last edited by Elltg; 17-12-10 at 11:13 AM. Reason: Tidying up/Re phrasing |
17-12-10, 11:27 AM | #3 |
Re: bar end weights
You could get a dremel and cut a flat groove in them so they can take a flat end screwdriver?
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
17-12-10, 11:52 AM | #4 |
Why no drilling? Easiest way to deal with this is drill the head off, withdraw the bar-end weight, and remove the rest of the screw with mole grips.
Replace with stainless allen head countersunk machine screws |
17-12-10, 12:24 PM | #5 | |
Re: bar end weights
You'll be amazed at how seized they get, mine was, as Mr Suzuki used no grease on assembly. Buy some stainless countersunk allen bolts to replace both. I got mine off t'Bay
17-12-10, 12:25 PM | #6 |
Re: bar end weights
17-12-10, 12:26 PM | #7 |
Re: bar end weights
They are made from cheese and easy to drill the head off
18-12-10, 11:14 AM | #8 |
Re: bar end weights
Be very careful with those horrors - they work a small percentage of the times they're used and every single engineering shop has plenty of experience of removing broken screw extractors.
Tapered ones are the worst. OP: Drill just the head off, remove the weight and there will be an inch of bolt to grip so you can remove it.
If an SV650 has a flat tyre in the forest and no-one is there to blow it up, how long will it be 'til someone posts that the reg/rec is duff and the world will end unless a CBR unit is fitted? A little bit of knowledge = a dangerous thing. "a deathless anthem of nuclear-strength romantic angst" Last edited by Sid Squid; 18-12-10 at 11:17 AM. |
18-12-10, 12:23 PM | #9 |
Re: bar end weights
Really? I will admit I have only had to remove 4 or 5 bolts with them but I found them great in use. On one bolt it had been bent and snapped off so that half was sat in the threads but applying pressure to each side of the threads making it absolutely stuck. It had about 1cm of 'threaded bar' hanging out the end and when i mull-gripped that to turn it and unscrew it, it literally snapped off leaving it flush to the hole. At which point the screw extractors did the job fine.
For future reference. What happens when they 'break'? Do the threads on them die? Would probably useful to be in the know about it, then I can watch out for tell tale signals! Would be one thing to have a bolt thread or round. It would be another entirely to embed a screw extractor in there as I try to remove it! |
18-12-10, 01:18 PM | #10 | |
Re: bar end weights
I agree with SS, why use one, when you can drill the head off this bolt easily. If you couldn't then use the extractor, but it would be my last option.
We're riding out tonight to case the promised land Make everyday count RIP Reeder - Jolly Green Giant and comedy genius Last edited by maviczap; 18-12-10 at 01:20 PM. |
Anyone else here trying to put on weight? | rubberduckofdeath | Idle Banter | 143 | 30-10-07 05:19 PM |
Chain buffer removal requires swing arm removal :-( | 2mths | SV Talk, Tuning & Tweaking | 1 | 09-07-07 09:19 AM |
What weight oil do you use? | andyb | SV Talk, Tuning & Tweaking | 23 | 24-06-07 02:27 PM |
Bar end weight | Diveboy | Stuff Wanted | 4 | 07-02-06 02:48 PM |
Weight | mpaton2004 | SV Talk, Tuning & Tweaking | 30 | 18-01-05 10:15 AM |
