Old 20-12-10, 08:31 PM   #1
MJFRACING
Default Minitwin parts - where from?
As a new owner of a sv650 k6 that i intend to use in the minitwin series, where is the best place to source gaskets/water pump seal kits and the like. The bike is in our front room in bits waiting for these spare parts!!!!!
Old 21-12-10, 09:46 AM   #2
hardhat_harry
Default Re: Minitwin parts - where from?
You can get alot of this stuff from Hi Level if you have an account.
Old 21-12-10, 10:42 AM   #3
or suzuki main dealers or wemoto
1 17400-19F50 PUMP ASSY, WATER. 1 MODEL K4/K5/K6
2 17411-19F50. CASE, WATER PUMP. 1 MODEL K4/K5/K6
3 17491-19F40. IMPELLER/SHAFT. 1
4 17470-02F10. SEAL, MECHANICAL. 1
5 09283-10004. OIL SEAL (10X21X5). 1
6 08110-69000. BEARING. 2
7 08332-11086. E RING. 1
8 17418-19F00. O RING. 1
9 17435-33400. O RING. 1
10 02112-06163. SCREW. 2
11 17415-20920. BOLT, DRAIN. 1
12 09168-08016. GASKET (8.2X14X1). 1
13 09103-06216. BOLT. 3
14 09280-22001. O RING (D:2.4,ID:21.8 ). 2
15 08331-31106. CIRCLIP. 1
16 17461-19F00. GEAR, WATER PUMP DRIVEN. 1
17 09181-10158. SHIM. 1
18 09261-04002. ROLLER. 1
19 09352-35653-600. HOSE. 1 L:600->320
I'm guessing your after items 8, 9 and 14 on the diagram. They work to be under £20 for the lot through wemoto (OEM Parts)
Old 21-12-10, 01:10 PM   #4
hardhat_harry
I'm doing a full engine rebuild and all the gaskets come to £70 at hi level which is a complete bargain.
It surprised me to find that the kit even has the valve stem oil seals in.
Old 21-12-10, 02:38 PM   #5
bloody hell!!
Wemoto want £130 for the same kit, how reasonable are hi level harry?
Old 21-12-10, 09:38 PM   #6
MJFRACING
Thanks for the info i will give them a try
Old 21-12-10, 09:39 PM   #7
MJFRACING
Your a star Thanks for the parts diagram great help
Old 21-12-10, 10:46 PM   #8
hardhat_harry
The only problem is you need an account it wouldn't surprise me to find Wemoto gets the part from Hi Level and slaps on a premium.
Old 22-12-10, 08:26 AM   #9
Would not be suprised.
Old 30-12-10, 06:08 PM   #10
tez
R&R Developments do everything for minitwins and the guy there is a minitwin specialist!!
custom kit sv 650 minitwin parts bike_slider For Sale - SV's and SV related items 5 09-11-10 05:43 PM
Mountain of SV / Minitwin parts and Spares see here RGV250ads Mini-Twins 1 18-09-10 07:50 PM
Minitwin / Inj SV650 parts for sale RGV250ads Mini-Twins 0 28-11-08 04:40 PM
Old Minitwin Parts For Sale LOOK SVFighter Mini-Twins 1 22-07-07 01:53 PM
Old Minitwin Parts For Sale LOOK SVFighter Mini-Twins 0 17-03-07 04:24 PM
