Old 30-12-10, 11:34 AM   #1
AndyBrad
Default Scottoiler nib installation.
Im thinking of knoacking something up to fix a second hand scottoiler i got off ebay to the s4.
Originally i would have gone with the axel washer type thingy. Unfortunatly i dont have one so im now thinking about splashing the cash on a dual injector as they look soo much neater. Unfortunatly i hear they dont work that well?
Soo any nice brackets youve seen for a scottoiler (or similar)?
Old 30-12-10, 11:43 AM   #2
fizzwheel
fizzwheel's Avatar
Default Re: Scottoiler nib installation.
Have you looked at the Scottoiler website, in the spares section, they have loads of different brackets and bits and pieces.
Old 30-12-10, 11:44 AM   #3
Lozzo
You don't need to make any brackets up at all, just drill a 5mm hole just behind the paddock stand bobbin lug and tap it to M6, then use a 8mm brake line P-clip to hold the pipe in place... like this
You can hold the pipe in place using a 6mm P-clip further up the swingarm... like this
These are shown on my Versys, but I did exactly the same on my SV650S K5 and it looked and worked great.
I'd avoid the dual-injector, they really aren't all they are cracked up to be and give problems.
Old 30-12-10, 11:47 AM   #4
AndyBrad
thats what i was thinking lozzo.....
Old 30-12-10, 11:57 AM   #5
Lozzo
Is easy to do and leaves it all looking very neat. The P-clips grip the pipe enough so it won't move from where you set it bu don't restrict the flow.
Old 30-12-10, 12:04 PM   #6
danf1234
Don't bother with the dual head. They are a waste of time. I had 3 and all went wrong. In the end scottoiler ended up refunding me part value of the oiler.
Old 30-12-10, 12:21 PM   #7
AndyBrad
yea ive heard similar things. looks a bit strange relying on foam to distribute the oil...
Old 30-12-10, 02:23 PM   #8
MattCollins
The hole doesn't need tapping although it is a nice touch. If you haven't got the taps, just use a stainless self tapper. It is not uncommon to find them in the swingarm holding the chain guard and hose guides.
Old 30-12-10, 06:00 PM   #9
danf1234
Trust me it doesn't work. I constantly ended up with one side feeding twice as fast as the other. Also when I parked up the nib would drain on the floor, and then become air locked and not work.
I went back to a single nib and I have never had an issue since.
Old 30-12-10, 06:01 PM   #10
danf1234
I wouldn't even consider drilling the swing arm unless you are 10000% sure you know what you are doing otherwise the outcome will be an expensive one.
Autocom Installation L3nny Bikes - Talk & Issues 33 20-04-10 10:53 PM
Battery Installation Binky Bikes - Talk & Issues 17 11-04-10 12:39 PM
New M4 slip on installation. Chet SV Talk, Tuning & Tweaking 7 17-05-08 10:03 PM
Scottoiler installation during bike warranty period alkap SV Talk, Tuning & Tweaking 15 13-07-05 02:05 PM
New Jet Kit installation? DoctorJ SV Talk, Tuning & Tweaking 6 02-05-05 07:31 PM
