Old 31-12-10, 04:58 PM   #1
bigchris
Default Carb cleaner, exactly where to use it?
Where do you actually spray carb cleaner? In the carb bowls? When the engines running?
Old 31-12-10, 05:03 PM   #2
leebex
Default Re: Carb cleaner
Best to use when the engine is running as it does strangle the air/fuel mix in the engine for a second or 2.
When ive used it, I just sprayed into the carb mouth, open the throttle a little too and spray some more.
Old 31-12-10, 05:03 PM   #3
hardhat_harry
Nope
Take carbs off
Undo float bowls
take pilot jet out spray in there
take main jet out spray in there
take emulsion tube out and guess what, spray in it
get rid off all brown goop inside float bowl by, you guessed it, spraying,
while you have the carbs off check linkages and grease
Old 31-12-10, 05:04 PM   #4
hardhat_harry
Spraying in the carb mouth will do naff all
Old 31-12-10, 05:04 PM   #5
B1k3R
You can spray small amounts into the airbox with the filter out and engine running. Too much will cut the engine.
Old 31-12-10, 05:04 PM   #6
leebex
never needed to go that far into myself hardhat_harry, although worth a go if its clogged up badly though.
Old 31-12-10, 05:05 PM   #7
hardhat_harry
Again this will do naff all as well
Old 31-12-10, 05:06 PM   #8
How would it clean the carb if it's put in when it's running?
I'm no expert, but I've always completely stripped the carb and cleaned out everything.
Old 31-12-10, 05:11 PM   #9
hardhat_harry
I think they are expecting it to mix with the petrol and magically clean the carbs.
The reason why carb cleaner is in a can with a high pressure spray is to blow any gunk away and clean it.
Old 31-12-10, 05:12 PM   #10
B1k3R
I disagree. Obviously it is not as effective as stripping the carbs and cleaning each part, remembering to wear rubber gloves because it dry's fingers to cracking point but it does clean all it touches so the jets and needles get a blast but not the bowl or floats.
TFR cleaner? dyzio Ancillaries 8 17-10-10 05:20 PM
Wanted: Clocks for carb model naked + headlight and carb. Gazdaman Stuff Wanted 2 17-03-10 03:50 PM
In-tank carb cleaner? Berlin Bikes - Talk & Issues 0 05-04-09 07:43 PM
Which Carb cleaner? Berlin SV Talk, Tuning & Tweaking 0 29-03-08 10:10 PM
the cleaner look PSU_shamokin SV Talk, Tuning & Tweaking 13 29-01-05 12:48 AM
