Old 06-01-11, 04:47 PM   #1
DavieSV
DavieSV's Avatar
Default How to measure spring rate?
Hi all.
Any one know how I can measure the spring rate using scales?
I have put a spring on some scales and slightly compressed it.
zero'ed readout.
Compressed it 10mm and the scales read 70kg,
Compressed it another 10mm and the scales read 149kg.
Can anyone determin the spring rate from these figures or am I just barking up the wrong tree
I cannot compress the spring any more because the scales will only go to 156kg.
DavieSV is offline   Reply With Quote
Old 06-01-11, 05:31 PM   #2
SV650Racer
Default Re: How to measure spring rate?
Ideally by taking it to someone who has a spring tester. If you post it to me and cover the return postage I can do it for you on ours.
Old 06-01-11, 05:52 PM   #3
best to get done on a test rig.
Is it a stock shock by any chance?
Old 06-01-11, 06:37 PM   #4
zadar
Originally Posted by DavieSV View Post
Hi all.
zero'ed readout.
That is the way, spring tester is scale. You just need precise way to measure compression of spring. 70kg for 10mm would be 7.0 spring.
Old 06-01-11, 06:55 PM   #5
flak monkey
Don't know what rate you want, but it works out to be ~415lb/in which is a standard spring rate measurement which you could convert to any other standard rate easily.
Old 06-01-11, 07:01 PM   #6
zadar
Actually ~390lb/in
Old 06-01-11, 07:05 PM   #7
flak monkey
Originally Posted by zadar View Post
Actually ~390lb/in
Depends which scale measurement you take:
149kg = 327lb for 20mm compression
20/25.4 = 0.7874
327/0.7874 = 415.29lb/in
70kg = 154lb
10/25.4 = 0.3937
154/0.3937 = 390lb/in
Old 06-01-11, 07:12 PM   #8
zadar
We just use 55.88 for conversion factor.
(1kg/mm)*(25.4mm/1in)*(2.2lb/1kg) => 1 kg/mm = 55.88 lb/in
Old 06-01-11, 07:58 PM   #9
DavieSV
DavieSV's Avatar
The spring is off an RSVR which I replaced my standard shock for a while ago.
I thought the standard spring was around 600lb, so I was expecting readings of around 105 @ 10mm and 210 @ 20mm.
Although it handled OK with this spring on and I could set the sag spot on, I was a bit worried about it being too stiff.
I replaced the spring with a 475lb spring I got off 21Quest, Setting the sag was only just within recomended limits and under hard acceleration with just a tail pack on, it squats like a jipsy who's drunk too much tea.
I have now got 1.0kg springs in the front so was considering putting the stiffer rear spring back on but thought I would try and determin what rate it actually was.
I think the scales are pretty accurate (but they have not been calibrated for years) and the displacement was crack on, I used the quill of a vertical miller to compress the spring and used slips to set the distance.
Old 06-01-11, 08:08 PM   #10
zadar
RSVR as aprilia 1000? those are usually in 500lb range for race bike with lighter rider.
If you using 1.0 in front you should be around 550 on rear.
sv1000 spring rate? bigchris SV Talk, Tuning & Tweaking 1 28-05-10 09:42 PM
spring rate calculation widget SV Talk, Tuning & Tweaking 2 23-11-09 03:43 PM
Spring Rate and Oil Weight? PURPLE SV Talk, Tuning & Tweaking 4 25-05-09 07:43 PM
Fork spring replacement... Forgot to measure travel beforehand. Troy SV Talk, Tuning & Tweaking 10 28-07-08 09:53 PM
Which spring rate for a chunky rider? Biker_Billy SV Talk, Tuning & Tweaking 11 04-02-08 12:27 PM
