Housemate went outside, came back in saying my bike was on it's side. Went out sure enough it's over. It was windy, but nowhere windy enough toblow it over, suggesting it was nudged by a car
![]() Bar end bold was bent, that can be replaced. However, my question is, the right footpeg and brake lever is bent. Can it be bent back? Or will it be made too weak and needs replacing? (can't post any pics until maybe tomorrow) Cheers Dan |
Nine times out of ten, trying to straighten die cast parts will snap them. This applies to brake levers, clutch levers and brake pedals.
I'm not sure about the foot peg. |
I would perhaps try the brake lever,but not the footpeg.Sometimes the peg can be cut off thus shortening the rear brake lever, then drill it and put a bolt through with petrol pipe on it.
Sorry to hear bout that mate. If u can bend it back, do as when i had my off the brake lever snapped off and it was bout 50 + quid to replace it from suzuki
Was SV650S K9 Now GSXR 600 K9 |
Look on eBay, you might be able to knock some of the breakers down on prices at this time of year.
If you have a blowtorch, then you have a fair chance on the leaver/s.
Basically take it off the bike, heat it enough so that when you rub a bar of soap on it, it turns black, then let it cool. You then have one chance to safely bend it back (vice and appropriate length of bending tube). The process is called annealing http://en.wikipedia.org/wiki/Annealing_%28metallurgy%29 If you bend it when hot or before heating then it WILL break! ![]() Hope that helps! Last edited by RenascenceBlue_; 10-01-11 at 10:37 PM. |
Rear brake lever direct from suzuki is £75
Front brake lever direct is £45. con. |
#8 | |
The bike is ride-able ish, will be better once the bar end is sorted out. Is there anything i should be looking out for as the bike has had a hard drop on its side and sat there for an unknown time (but not more than 2 hrs) |
#9 |
mate theres complete rh hangers on ebay for 40 odd quid
#10 |
Straightening up out of a corner | cF^ | Bikes - Talk & Issues | 18 | 18-02-10 07:49 AM |
men straightening their hair? | malks | Idle Banter | 96 | 28-08-08 08:12 AM |
wanted - foot peg and foot brake lever | bikerman | Stuff Wanted | 2 | 03-10-06 10:47 AM |
wheel needs straightening! | socommk23 | SV Talk, Tuning & Tweaking | 16 | 17-05-06 09:07 AM |
