Old 12-01-11, 04:29 PM   #1
Reeder
Default How much do you use the rear brake?
When learning I obviously was taught to use as well as my front however as time went on after passing I found myself using it less and less until it's basically got to the point of only really using it when at a stop to make sure I'm not going to roll anywhere.
Is this a bad thing?
Old 12-01-11, 04:32 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: How much do you use the rear brake?
fronts more effective but not as smooth as rear i feal, im a big rear brake person using it mostly to keep the front down off the lights, use it more in winter and as and when road conditions require as a rear wheel loss of traction is far easier to handle than loss of front
as someone also said, front pads/disks are more expensive than rear too ;p
Old 12-01-11, 04:35 PM   #3
I use mine a fair bit, especially when coming to a quick stop from speed, sometimes I comfort brake when cornering, hardly touch it tbh, just seems to help.
Mainly use it for slow control in urban areas.
Old 12-01-11, 04:36 PM   #4
Scoobs
I use the rear a lot. Really helps to balance the bike, especially when I'm heavily on the front brake. I use it for tight, low speed corners to help drop the bike in.
Old 12-01-11, 04:43 PM   #5
Stu
Trinity
Stu's Avatar
IMO - not a good example to use it.
I use mine a lot
Old 12-01-11, 04:44 PM   #6
As TSM its a lot easier to control a rear end slide than a front end washout
I use it a lot in the city, for low speed stuff and the sh*** weather aswel.
Old 12-01-11, 04:48 PM   #7
Berlin
0%, nada, nowt, never.
Except as something to put my toes on when my right foot is on the peg sitting at junctions and the like
Old 12-01-11, 04:49 PM   #8
Jayneflakes
Jayneflakes's Avatar
I am quite fond of my rear brake, I use it as a controlling brake to scrub speed before a corner and for slow control moving. Mind you, I use this technique on the mountain bike and it seems to have transfered well to the big bike. At the moment I am cautious with the front brake since it locked the wheel braking for a junction that had a big metal manhole cover on it, scared me for a second that did! Slimy winter roads are not nice to powerful front brakes...
Jayne you're a Pussy Magnet
Old 12-01-11, 04:51 PM   #9
speedplay
There is a rear brake too...?!
Old 12-01-11, 04:53 PM   #10
benji106
When sitting at the traffic lights, when I go skidding into the garage at the end of a ride out and the odd occasion in between, mostly slow speed stuff when filtering.
Curvy brake lever & rear brake pedal Old Git Stuff Wanted 1 09-01-10 11:00 AM
Brake light not coming on with rear brake. XmisterIS SV Talk, Tuning & Tweaking 5 11-12-09 12:06 AM
footpeg bracket, rear rear brake lever, clip on. plowsie Stuff Wanted 3 05-08-09 03:44 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Brake light not working when rear brake is used.. StreetHawk SV Talk, Tuning & Tweaking 10 16-04-07 03:40 AM
