Old 14-01-11, 11:38 PM   #1
muzikill
muzikill's Avatar
Default 98-02 gearbox ok for k3?
As it says! ......
Old 15-01-11, 02:08 AM   #2
zadar
Default Re: 98-02 gearbox ok for k3?
Yes. But only if it is 03.
Old 15-01-11, 10:38 AM   #3
muzikill
muzikill's Avatar
53 plate ....... pointy
K3 gearbox muzikill Stuff Wanted 0 12-08-10 08:34 PM
Gearbox Richie Stuff Wanted 0 09-07-07 08:09 PM
Gearbox Fix? seandixie SV Talk, Tuning & Tweaking 11 29-06-07 09:32 AM
Gearbox Daglad SV Talk, Tuning & Tweaking 12 02-04-06 09:26 PM
Gearbox sprocket. cassius SV Talk, Tuning & Tweaking 6 02-02-05 11:33 PM
