Old 16-01-11, 05:01 PM   #1
muzikill
muzikill's Avatar
Default Engine cleaning b4 engine strip w.i.p
http://forums.sv650.org/showthread.php?t=160198
Following on from the above thread...
Thought i would let you lot see how the workshop is looking so far, microwave (check), tv for the forthcoming motogp season (check). As you can see the engine is on the bench...
Top half of the engine cleaned using a gunky rag, nylon brush & compressed air.
The area around the gear selector and front sprocket is a bit tricky...
Old 16-01-11, 05:41 PM   #2
muzikill
muzikill's Avatar
Default Re: Engine cleaning b4 engine strip w.i.p
And now working on the underside...
Pretty crudy - getting there though!
Old 16-01-11, 06:20 PM   #3
Teejayexc
Never mind the tv and the microwave...where's the fridge for the beers
engine bolts for point engine pookie Stuff Wanted 6 01-10-10 01:50 PM
Engine Breaking? Hopefully not. Engine braking - is that OK? butterick99 SV Talk, Tuning & Tweaking 14 12-09-09 10:31 PM
Dead Sv Engine or Engine block.... Andy Jeffries Stuff Wanted 6 15-08-09 07:46 PM
Cleaning engine casings. Gary C Bikes - Talk & Issues 1 01-06-08 07:23 PM
Engine braking... any hazzards engine wise? John 675 SV Talk, Tuning & Tweaking 21 28-03-08 07:20 PM
