Old 16-01-11, 10:52 PM   #1
Owenski
Default 2.5hp 10bar 50l electronic air compressor.
Is this any good, specifically for spray painting with the air gun? but generally will this do what any tom/dik/harry in their garage might wanna use it for?
Better yet has anyone got one? Any comments would be awsome cheers
Old 16-01-11, 10:58 PM   #2
Owenski
Default Re: 2.5hp 10bar 50l electronic air compressor.
ooopps for got the link
http://www.screwfix.com/prods/33988/...r%20Compressor
Old 16-01-11, 11:00 PM   #3
I'm no painting expert but it will run air tools fine
Old 16-01-11, 11:09 PM   #4
Owenski
awsommmmmmmeeee! Costco are selling them £100 they only had about 12 left this afternoon but I've been given permission to head back there tomorrow and pick one up (provided I pick up a load of other gubbins too).
Old 16-01-11, 11:13 PM   #5
Actually, that won't run all air tools, I know cos I've got one.
It's the cfm's that are important with compressors, a decent spray gun will require a fair amount of air.
Buy a gravity fed spray gun as they are better suited to smaller compressors as they are more efficient.
I bought an impact gun for mine, supposed to require 6cfm, my compressor wouldnt run it properly so I took it back.
Things like sand blasters require 10cfm's + so you've got no chance.
The 50 litre tank will certainly help though.
Old 16-01-11, 11:20 PM   #6
Owenski
lol I've just read very similar to what you've typed about the cfm's It did say though that anything over 2hp will give more than 7cfm which is all thats required for gravity fed spray guns so im pleased with that.
Old 16-01-11, 11:29 PM   #7
But that's max, that means if your running something even close, it will be running constantly.
Old 17-01-11, 12:06 AM   #8
Owenski
so its not as much the compressor as the gun which is pivitol regarding spraying
Old 17-01-11, 12:31 AM   #9
True, but once you start trying to move a lot of atomised paint like the pros, you will need a bigger compressor.
It's a smooth regular supply that's important.
I've done a bit of spraying with my gravity gun, had to be very much thinned to get it to spray ok.
Old 17-01-11, 07:44 AM   #10
timwilky
timwilky's Avatar
You will also need an oiler and evaporator for your tools, but don't get oil in your line or it will screw up your paint. for that reason I have two feeds off the compressor one with an evaporator/regulator/oiler and the second with an evaporator/regulator and different fittings so I cannot use any tool lines with my spray guns.
Besides which, I also have a pressure fed mask, don't want to be breathing oil.
If you can afford it get a bigger one, probably better to buy ex industrial than a cheap little one, if of course you have the room.
Not Grumpy, opinionated.
Who needs a compressor .. Blue_SV650S Idle Banter 15 26-04-08 08:35 AM
compressor husky03 Idle Banter 5 05-02-08 08:21 PM
For PC electronic gurus mysteryjimbo Idle Banter 12 13-06-06 07:29 PM
Electronic TRE Jonooffler SV Talk, Tuning & Tweaking 3 26-05-06 11:51 AM
How big a compressor do I want? northwind SV Talk, Tuning & Tweaking 20 05-07-05 12:10 PM
