Old 18-01-11, 06:41 PM   #1
adjblade
Default Injected Front Wheel Axle and Front Master Cyl Brkt
A couple of silly little things needed if kicking around in your garage
Front wheel spindle/axle
Alloy front master cylinder bracket to fix resevoir to clip-on
Thanks
AJ
Old 19-01-11, 06:58 AM   #2
Nobbylad
Nobbylad's Avatar
Default Re: Injected Front Wheel Axle and Front Master Cyl Brkt
Hello mate... think I have a k8 spindle will check and let you know
Old 19-01-11, 08:07 AM   #3
adjblade
Thanks
SV650 Front Wheel - Do any other Suzuki models use the same front wheel? williamturner1 SV Talk, Tuning & Tweaking 11 30-05-10 02:31 PM
Wanted: SV650 Front Wheel (2004,"pointy",Injected) williamturner1 Stuff Wanted 6 08-02-09 11:01 PM
GSXR 750 k4 front wheel axle part. Caddy2000 Idle Banter 4 22-12-08 10:56 AM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
front wheel maintenance ?? need to prop up front wheel etc valleyboy SV Talk, Tuning & Tweaking 2 26-08-05 07:50 PM
