Old 18-01-11, 10:25 PM   #1
tigersaw
tigersaw's Avatar
Default JIS screwdrivers
Anyone know where to get a set of JIS screwdrivers in the UK?
I want to take the carb apart and rather than cheese up the screws I'd prefer to use the correct tool
Old 18-01-11, 10:37 PM   #2
Default Re: JIS screwdrivers
No idea, if you find some that aren't utter crap do let us know.
Old 18-01-11, 10:44 PM   #3
toxic
Impact driver and replacement screws work for me.
Old 18-01-11, 10:46 PM   #4
Lol +1
I tend to use PH bits in impact driver (carefully!)
Old 18-01-11, 10:51 PM   #5
What's different about them to normal bits?
Old 18-01-11, 10:52 PM   #6
Slightly different shape
Old 18-01-11, 10:57 PM   #7
tigersaw
tigersaw's Avatar
Philips screws and screwdrivers are designed to 'cam out' if over torqued, protecting the work but mullering the screw. Using a philips screwdriver to unwind a stiff JIS screw will cheese it up for that reason.
Old 18-01-11, 11:09 PM   #8
Ask Ed. He seems to know about the two types of drivers
Old 18-01-11, 11:13 PM   #9
embee
embee's Avatar
I always worked loosely on the basis that JIS was effectively Phillips with a radius, but reading further like here it's more the other way round, Phillips is JIS with a taper (though Phillips came along a long time ago, way before JIS). It appears that Phillips is actually designed to cam-out (as Tigersaw says), it was done for early machine assembly with no mechanical torque control. JIS (and Pozidrive) have parallel sides and don't cam-out as easily, auto assembly uses torque control.
Having read all that, I use good quality Phillips bits in JIS screws with very few issues usually, the problems get much worse as the bits wear and get more taper on them. Pozidrive doesn't fit at all (they're the ones with the extra notches in the inner corners of the recess, angles are all different and they just don't match Phillips or JIS).
Old 19-01-11, 12:22 AM   #10
beabert
Well you learn something everyday! i want some now, assuming there are jis screws on the SV
