Old 21-01-11, 08:59 PM   #1
curvy custard
Default Best fork springs for curvy?
im very near to changing oil and seals on my front forks, whilst im there im going to replace the springs, has anyone got any experience of the ohlins springs available from jhs racing? any advice on what else to use?
Old 21-01-11, 09:27 PM   #2
Default Re: Best springs for curvy?
what weight are you without leathers?
Ohlins and K-techs are the same virtually quality wise. SV650Racer on here will be able to give you a little bit of discount.
I've got the k-techs as they're cheaper than the ohlins and in stock in the UK most of the time, the ohlins you way weight a few weeks for.
I've got K-techs with Putoline race susp fluid and there ok.
Old 21-01-11, 09:42 PM   #3
Tim in Belgium
Linear steel ones FTW
Old 21-01-11, 09:49 PM   #4
curvy custard
Im 67kg and looking to prep the bike for a few track days this year,
Old 21-01-11, 10:00 PM   #5
Tim in Belgium
Linear and get on to one of those spring calculation websites, I'm sure someone will be along with a link soon as to what rate you need. Go for the later curvy ones and fit a set of preload adjusters to make adjusting the preload easy. Some thicker fork oil and you'll be fine on a track day.
Old 21-01-11, 10:08 PM   #6
Tim the wise budda follow his tips
Spring weight you'll be looking at 0.8 to 0.85 kg/mm
15w oil too
Old 21-01-11, 10:11 PM   #7
Jordy
Is it dangerous to only upgrade the front? I just read this:-
Does this require changing the rear shock as well to maintain balance between the front/ rear?
Yes. If you stiffen up the front end w/o increasing the rear ride height you will find that the bike has way too much weight on the back of it. As you get moving quickly (100? mph or so...) the bike will start wobbling, then headshaking. Bad. Very bad. When I bought my bike it was stock, it was friday pm, and I was racing the next day. Added preload to the front forks to get the proper sag. It wobbled BAD. Dropped the front ride height, and it still wobbled. Played around in EVERY morning session (****ed off race control..) trying to get the bike to work, then I gave up and put it back to stock preload and ride height and it stopped wobbling.
Old 21-01-11, 10:13 PM   #8
I've never had that above 100mph with me stock shocker.
Had impressive controllable wheelies off big crests
Old 21-01-11, 10:27 PM   #9
curvy custard
im up for changing the rear too, thats why credit cards were invented and why im doing lots of overtime at present lol
Old 21-01-11, 10:28 PM   #10
Haha
What you budget for the rear?
Standard Curvy Fork Springs paiste For Sale - SV's and SV related items 5 04-05-10 08:22 PM
0.85kg Curvy fork springs 7755matt Stuff Wanted 0 06-04-10 08:59 AM
Uprated fork springs for a curvy. streetos Stuff Wanted 0 06-03-06 09:33 PM
Will SK1 front fork springs fit a curvy? streetos SV Talk, Tuning & Tweaking 3 17-06-05 02:48 PM
