View Poll Results: heat wrapping exhausts?
yes 2 12.50%
no 14 87.50%
Voters: 16. You may not vote on this poll
Old 23-01-11, 01:30 AM   #1
svsam
svsam's Avatar
Default Heat wrapped exhausts?
what do you think?
SL0 jack up kit-yoshimura can-tial tidy-(so far)
svsam is offline   Reply With Quote
Old 23-01-11, 01:32 AM   #2
barwel1992
Default Re: heat wrapped exhausts
i heard that it accelerates rust as it keeps moisture in
Old 23-01-11, 01:34 AM   #3
svsam
svsam's Avatar
what about those kits you can get for about £100+? they must have some kind of protection added.
Old 23-01-11, 01:36 AM   #4
barwel1992
no idea, we use them on the race cars and considering they get removed and cleaned after every wet race the rust still builds up where the rap is applied
not saying that you can get stuf that would work though.
whats the reasons you want to do it ?
Old 23-01-11, 01:39 AM   #5
svsam
svsam's Avatar
i think it looks pretty smart, not sure how ide work around the brackets and jubilee clips on the pipe though, that could look a bit dogey!
i like the look of that one with the custom mani on svrider.com, im sure you know the one i mean.
Old 23-01-11, 01:43 AM   #6
barwel1992
Default Re: Heat wrapped exhausts?
ohh i see, some more info hear about the water issue
http://www.advrider.com/forums/showthread.php?t=264521
Old 23-01-11, 02:28 AM   #7
Bluefish
I just think it looks ****, why buy an expensive exhaust then cover it up?.
Old 23-01-11, 09:54 AM   #8
Nothing nicer than a polished downpipe why cover it in a bandage which will get covered in sh1te
Old 23-01-11, 10:16 AM   #9
looks shi1te, however according to some members on the Raptor chapter, its recommended on the rear downpipe, due to it being so close to the shock, apparently keeps the heat in so it don;t boil the shock fluid. Not sure if it works but hey, better than your bike suddenly pi$$ing everywhere and suddenly resembling a pogostick.
Old 23-01-11, 11:32 AM   #10
No advantage, would cause most factory pipes to disintegrate quicker.
Its mainly used on the forgotten era racers with stainless pipes, stops them being ground out
DB; R&G do a shock tube now which is meant to stop the crap and reduce the heat transfer
Heat? Dicky Ticker Bikes - Talk & Issues 2 04-12-10 09:49 AM
Vinyl wrapped fairings? husky03 Bikes - Talk & Issues 11 29-12-08 09:26 AM
how to heat up your Tea hang man Idle Banter 2 02-11-08 01:46 AM
exhaust cans re wrapped gaz-sv650s SV Talk, Tuning & Tweaking 6 21-08-08 07:20 PM
