Old 25-01-11, 12:48 PM   #1
Jimgreg
Default Y9H yellow but what black is it?
I've found some saddle shutters s2-concept but now I don't know black the black bits are, can anyone help?
Old 25-01-11, 04:25 PM   #2
davepreston
Default Re: Y9H yellow but what black is it?
if you made the sentence above mean something id be glad to help
Old 25-01-11, 07:43 PM   #3
Jimgreg
I'll Try again, I have a sv in pearl yellow and I have the colour code for that but it seems there are different types of black paint for the sv and I am unsure which one mine is my current yellow paint code is y9H
Thanks
Old 25-01-11, 08:16 PM   #4
punyXpress
punyXpress's Avatar
do you mean the triangular bits you take off to get at the front seat bolts?
Now: Street Triple R
Old 25-01-11, 08:41 PM   #5
saddle shutters are the things you put in the holes wear the grabrail used to be when you've removed it.
They aren't painted AFAIK, just a generic plastic, although I may be wrong.
If I'm wrong with your description 'saddle shutters' I can only assume you mean the seat infills...ie the triangular plastic grills below the seat. They aren't painted either, again they are a generic black plastic.
Old 25-01-11, 09:48 PM   #6
Jimgreg
Hi your spot on with the grab rail infill, I've found some .... In France believe it or not .... However they come in three colours, Black, Antharcite and White. Now I've head that Anthracite is a coal colour ( sounds like another black to me) so now I have the problem of which is the 'black' on my yellow K1 that will match the black on my tail piece
Old 25-01-11, 09:53 PM   #7
The bit over your rear light is the black it should be, its certainly not a charcoal colour
Old 25-01-11, 10:12 PM   #8
Jimgreg
Awesome thanks I'll go with that
99-01 Seat Cowl Black/Yellow wanted blanc Stuff Wanted 0 06-02-09 09:41 AM
Yellow '04 black frame. fatneck SV Talk, Tuning & Tweaking 18 22-10-07 03:16 PM
97/98 black yellow & purple blade hovis South & West Surfers 2 09-09-07 01:36 PM
Black curvey yellow wheels gettin2dizzy Pennine Massive 1 04-06-07 12:36 PM
yellow or black seat cowl for curvey Viper Stuff Wanted 1 17-11-06 02:11 PM
