Old 06-02-11, 08:55 PM   #1
Lego
Unhappy Bike laid up - what to check to run again?
In August I was laid off from my job, rode the SV home and parked her in the garage. She has sat there ever since...
Well I'm looking to get her back out... What should I look at doing to get her back on the road? Obviously need to change the battery, but are there any reccomended checks I should do?
Lego
Old 06-02-11, 08:57 PM   #2
barwel1992
Default Re: I've commited the worst sin!
check oil level fuel should be ok "ish" check chain for tight spots just generally lube every thing
do tire pressures
Old 06-02-11, 08:58 PM   #3
mattSV
mattSV's Avatar
Might need a change of fuel - unleaded has a tendancy to 'go off' after 3/4 months.
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 06-02-11, 09:08 PM   #4
Yeah it can go more sticky and soldify a bit.
You can recycle the fuel, just mix it with fresh stuff but not all at once, put a bit in every fill up.
Or use it to light your BBQ in the summer
Old 06-02-11, 09:08 PM   #5
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Fuel should be fine after just a few months, I've had fuel sit for ~18months and be perfectly good to use, not as good as new stuff but the bike will run OK, if you're very concerned just top up with fresh stuff to dilute what's in there
Battery may need replacing but it might be worth a charge first and monitor how well it retains it
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 06-02-11, 09:10 PM   #6
do tire pressures
How would the chain get tight spots sitting in the garage?
Old 06-02-11, 09:44 PM   #7
The Idle Biker
Take it easy when you get back on and give yourself time to readust , then have a blooming good time on it this summer.
Old 06-02-11, 09:50 PM   #8
Lego
Thanks Guys!!
I got spare battery so will just sling that in there and charge the one thats in the bike
Darren I'm guessing hes referring to chain rusting? sorry cant remember how to quote and stuff... Been a while since I been on here
Thanks again
Lego
Old 06-02-11, 09:51 PM   #9
Lego
Haha! Just as i post that I find it :P
Old 06-02-11, 09:56 PM   #10
SoulKiss
SoulKiss's Avatar
Mine was fine after 3 years...
█╬╬╬╬(•)iŻi▀▀▀▀▀█Ξ███████████████████████████████)
Laid-up Bike Insurance sv182 Bikes - Talk & Issues 4 09-11-09 03:32 PM
Laid off, advice needed. timwilky Idle Banter 10 08-09-08 12:58 PM
Laid back biker the_elements_600 Idle Banter 5 13-07-08 12:39 PM
Need to check parts for my bike TSM SV Talk, Tuning & Tweaking 5 23-02-06 11:52 AM
