Old 07-02-11, 01:49 PM   #1
Stig
Default Broken off bolt, what tool to use?
The bolts holding the brake line cables in place have snapped off. Both of them can you believe it?
What tool would you use to extract the bolts?
ezee out or something else?
Old 07-02-11, 01:52 PM   #2
Kilted Ginger
Default Re: Broken off bolt, what tool to use?
yep, ezee out / screw extractor, call it what u will.
Preperation is the key, dont rush it.
if u can file the head flat and use centre punch before drilling. start small and work out, go as big as you can without damaging threads before using extractor. hth
Old 07-02-11, 02:07 PM   #3
Stig
That's what I thought. Thanks.
Now to find a new battery for my Dewalt.
Old 07-02-11, 02:33 PM   #4
_Stretchie_
Large Member
_Stretchie_'s Avatar
Have you got any thread sticking out?
How to amuze an idiot:
Look right-> <-Look Left
Old 07-02-11, 02:49 PM   #5
Drill it out on center until you break into the minor diameter of thread and then you can pick the threads out with a scriber or something. Or buy some LH twist drills, they are very good.
Old 07-02-11, 02:53 PM   #6
Kilted Ginger
This requires a certain level of technical ability. Whilst i'm not saying stig does not have this level i, rightly or wrongly normally err on the low side of knowledge / expertise when offering advice from my limited knowledge
Old 07-02-11, 02:57 PM   #7
Oh yeah I know, it's just that EZ out's aren't very easy to get out when they snap (which they are prone to). They are a last resort for me.
Old 07-02-11, 02:59 PM   #8
Stig
I've drilled bolts out before as Chris has stated, but I haven't used any other method. I have heard the ezee out is less likely to end up with something going wrong and each time I hear of bolts being snapped in, the bolt exctractor is the thing that seems to be mentioned the most.
Old 07-02-11, 03:05 PM   #9
Reasons;
The bolt wasn't strong enough to undo itself, an EZ out is much smaller, brittle due to it's hardness and has threads which propagate into cracks.
The EZ out is a taper, which is screwing itself into the bolt as you use it, meaning the harder you twist, the harder it goes in, expanding the bolt which will lock it into the hole harder.
Just my opinion, but I have snapped a few and had to oxy torch them out (bloody difficult with an ally part you don't want to melt).
Old 07-02-11, 03:54 PM   #10
Stig
Reasons;
I read the same thing when doing a search for them. It Would seem it can be hit and miss between an easy job and a fg bch of a job.
I still think I'll give the extractor a go though. The bolts were copper greased so I think it wouldn't take that much purchase to coax them out. If it gives me the impression they are not going to come out easily, I'll revert back to drilling them out.
Ignition barrel bolt tool? bigchris SV Talk, Tuning & Tweaking 19 08-02-11 11:02 AM
Exhaust bolt broken off in Head Aidan SV Talk, Tuning & Tweaking 8 24-09-08 11:08 AM
Startrek.steve broken, SV650 broken too startrek.steve Bikes - Talk & Issues 31 26-08-08 12:49 PM
SV Tool Kit/Spark Plug tool svdemon Stuff Wanted 1 17-12-07 12:29 PM
Help - broken bolt. New Leaf SV Talk, Tuning & Tweaking 10 30-11-07 07:55 AM
