Old 10-02-11, 03:26 PM   #1
bigchris
Default Curvey carb slide
Hey all, after the black plastic diaphragm slide that houses the carb needle ???
Old 10-02-11, 08:32 PM   #2
Elltg
Default Re: Curvey carb slide
Did you need the rubber diaphragm or the plastic part the needle slides through (the part that gets changed to restrict the bike)
Old 10-02-11, 08:36 PM   #3
bigchris
I need the plastic slide, not the rubber diaphragm?
Do you have one?
Old 10-02-11, 08:44 PM   #4
Elltg
I have the restricted 33bhp ones. Any use to you? £20 posted?
Old 10-02-11, 09:16 PM   #5
bigchris
Cheers but I need the unrestricted ones. Thanks anyway.
Old 10-02-11, 11:38 PM   #6
Elltg
No problem man, best of luck and a free bump to hopefully get you the parts asap!
Old 10-02-11, 11:40 PM   #7
beabert
Just block the two holes up
Old 11-02-11, 07:51 AM   #8
bigchris
What would I use to block the holes up? Blue tack! ,
Old 11-02-11, 10:27 AM   #9
beabert
No plastercine
Old 21-02-11, 08:59 PM   #10
Soprano69
I've got a pair of these if you still need them. Make me an offer and they can be yours.
Wanted: Clocks for carb model naked + headlight and carb. Gazdaman Stuff Wanted 2 17-03-10 03:50 PM
Wanted. Curvey standard carb slides. ZXRich Stuff Wanted 0 13-09-09 06:29 PM
SV curvey with 30HP after carb clean!? Grounded! :( F16Falcon SV Talk, Tuning & Tweaking 12 07-09-09 03:18 PM
Unbelievable Slide! lukemillar Racing and Paddock Chat 10 20-08-08 05:40 PM
carb slide flutter mregehr SV Talk, Tuning & Tweaking 3 27-03-06 11:27 AM
