Old 12-02-11, 05:42 PM   #1
Dr.Tom
Default Standard valve shims?
Could somebody tell me the size of the shims that the SV650 K3 left the factory with or something roughly close?? Reason being is my loose cylinder heads were turned upside down and the buckets and shims fell out. I recovered everything except one shim and dunno where to start What I currently have is:
1.80mm x2
1.75mm
1.70mm
1.55mm x2
1.72mm
Old 12-02-11, 05:52 PM   #2
Default Re: Valve shims
Having a quick look at the clearances 1.70 is std.
this should have the clearances in
Originally Posted by Electro View Post
I posted the following a bit ago if you wnt to add them mate
1_General_Information.pdf
http://www.megaupload.com/?d=KCES1PF6
2_Periodic_Maintence.pdf
http://www.megaupload.com/?d=UKB3GBYL
3_Engine.pdf
http://www.megaupload.com/?d=Y22A8I69
4_Fuel_and_Lubrication_System.pdf
http://www.megaupload.com/?d=MQ931SVF
5_Cooling_System.pdf
http://www.megaupload.com/?d=1UBNTNHR
6_Chassis.pdf
http://www.megaupload.com/?d=N8W3U2Z0
7_Electrical_System.pdf
http://www.megaupload.com/?d=8VW5OCU4
8_Servicing_Information.pdf
http://www.megaupload.com/?d=8JKZ33OK
9_10_Emission_Contro_ Info_SV650Y.pdf
http://www.megaupload.com/?d=2B69MUXV
Cheers, Electro.
Old 12-02-11, 06:10 PM   #3
Fire some in and play around until they are right.
You want 0.1-0.2mm intake, 0.2-0.3mm ex.
There is not a standard size, could be anything.
Old 13-02-11, 10:05 AM   #4
mikerj
Default Re: Standard valve shims?
There are no such thing as "standard" shim sizes, they are all selected when the engine is built to give the correct valve clearances.
Valve clearances - what shims do I need? Wideboy Bikes - Talk & Issues 21 24-06-10 11:13 AM
sv650 shims and valve clearances tommy-d SV Talk, Tuning & Tweaking 1 28-07-09 06:57 AM
Shims yorkie_chris Stuff Wanted 3 14-11-08 01:26 PM
Valve shims yorkie_chris SV Talk, Tuning & Tweaking 14 03-11-07 08:06 AM
Valve shims and battery yorkie_chris SV Talk, Tuning & Tweaking 0 29-05-07 04:48 PM
