Old 13-02-11, 10:31 AM   #1
mikerj
Default Pointy steering lock and GSXR top yoke?
I've hunted through what seems like hundreds of threads, but I can't find out if there is a combination of standard GSXR parts that will allow you to retain the steering lock on a pointy. Ideally to suit the GSXR600 K1-K3 RWU forks, but could go USD if needed.
Old 13-02-11, 10:43 AM   #2
Default Re: GSXR Top yoke
Funny you mention it but if you use the GSXR K1-K3 the steering lock and lockstops work fine. You can use 600 750 or thou, I've fitted all 3 with no problems.
Old 13-02-11, 11:23 AM   #3
mikerj
Default Re: Pointy steering lock and GSXR top yoke?
Thanks Chris, that is great news as I have a set of K2 yokes. I had doubts it would work due to the offset position of the ignition switch/lock.
Old 13-02-11, 11:24 AM   #4
Stock is offset too?
Old 13-02-11, 11:33 AM   #5
mikerj
Yep, I meant offset from the standard location. I rested the top yoke over the standard one on my bike just to eyeball it and it looked as though the ignition switch cutout in GSXR yoke was not fully aligned with the SV. Looks like my eyeballs need recalibrating
Old 13-02-11, 11:37 AM   #6
They might not be the same, I think GSXR might have a bit less turning range so they'd need to be different... anyway I never measured anything, just bolt them up
Steering lock - stuck off? ooger Bikes - Talk & Issues 6 09-08-09 09:26 AM
Steering lock for Steering damper Sideshow#36 SV Talk, Tuning & Tweaking 8 30-08-07 11:18 PM
Steering lock problem $tevo SV Talk, Tuning & Tweaking 2 20-04-07 10:09 PM
Steering lock (grrrrr) zedleppelin1981 SV Talk, Tuning & Tweaking 5 18-03-07 12:25 AM
steering lock to lock??? thumper SV Talk, Tuning & Tweaking 16 29-01-07 07:17 PM
