Old 14-02-11, 03:01 AM   #1
erevojoe
Default Broken choke cable splitter.
Guys,
I have a 99 sv650 with a 03 motor converted to carb. I have found that the choke cable is only pulling the choke on the rear carb and the front isn't connected at the Y. I have to stick my hand up to the carb and pull on the little piece of cable sticking out of the carb right after the 90deg bend going into the carb body. Can you buy the piece that connects this part into the Y or must I buy a whole new assy? Can the Y be taken apart? I didn't see a way to get it apart.
Also, where is a good place to get parts online? I need new intake maniflods but the only place I have found them was jcwhitny, and they only sell generic ones by the flange size and bolt spacing. The rear one needs to have the vacuume port for the petcock and I didn't figure these would come with that as well as not knowing exacly which ones I need or what side of the manifold to measure. Thanks guys
Old 14-02-11, 07:49 AM   #2
rictus01
rictus01's Avatar
Default Re: choke cable Y
No you can't buy just that part, the cable comes as a complete assembly.
Online try
http://www.robinsonsfoundry.co.uk/
http://www.sparesdirect.co.uk/
http://www.wemoto.com/
Choke Cable HopefullySoon Stuff Wanted 1 07-12-07 12:13 PM
choke cable? husky03 SV Talk, Tuning & Tweaking 6 02-12-07 07:11 PM
Choke Cable SV650Guern SV Talk, Tuning & Tweaking 11 26-05-07 02:06 AM
New Choke Cable Anyone? Magoo Soho Massive 0 06-03-07 09:35 AM
