Old 16-02-11, 12:02 AM   #1
davepreston
Default power commander buying
can i buy any bikes power commander then just upload the sv1000 maps
or do i need sv thou specific
Old 16-02-11, 12:34 AM   #2
paiste
I was wondering this sort of. I was wondering if a Sv650 pc111 would fit? At least its a Suzuki fitment. I'd imagine they would have manufacturer specific connections Dave.
Old 16-02-11, 01:01 AM   #3
davepreston
Default Re: power commander buying
even that ould keep the price down as gsxr ones are up all the time
Old 16-02-11, 07:48 AM   #4
paiste
I'm sure someone far more knowledgeable than us will.be on in a minute to tell us its fine. Then it will.be ebay time!
Old 16-02-11, 07:58 AM   #5
barwel1992
from my dealings with them on a xt660 and mt-03 the unit is the same but the detachable loom and connectors are diff so you should be able to use the unit on most bikes with the correct loom dont take this as gospel though
the only thing that may differ is if they are programmed for 1/2/3 or 4 cylinders
Old 16-02-11, 07:58 AM   #6
barwel1992
but why do you want one when you can just map the stock ecu
Old 16-02-11, 08:48 AM   #7
pookie
pookie's Avatar
I know you can use older sv1k powercommanders with newer models and the only thing that changed was the default map
Old 16-02-11, 08:49 AM   #8
flymo
flymo's Avatar
no Dave, they usually come with specific loom connectors built in and vary in spec. Not worth the hassle, get the right one to start with.
Old 16-02-11, 10:29 AM   #9
speedplay
Because you can make your own maps and change the settings as and when you want to yourself...?
Old 16-02-11, 10:33 AM   #10
SV650Racer
You cant make accurate maps or maps worth having unless you are running a live AFR system/self mapper or have access to a dyno. Every bike will fuel different and require a totally different map to another even if they are identical. Injector flow rates, engine tolerances etc all affect the map required.
IMHO its not worth messing with unless your changing things on the bike that would affect the mapping.
Direct to ECU maps work fine for 99% of bikes out there.
Power Commander usb Davie For Sale - SV's and SV related items 3 18-05-08 11:06 PM
power commander daddydan SV Talk, Tuning & Tweaking 30 16-05-08 10:01 AM
Gen 2 Power Commander VOID Stuff Wanted 0 30-03-08 01:11 AM
Power Commander danf1234 SV Talk, Tuning & Tweaking 10 25-03-07 12:01 AM
Power Commander power graph print outs. JimPSV SV Talk, Tuning & Tweaking 19 27-11-06 09:39 AM
