Old 24-02-11, 10:09 PM   #1
mikerj
Default Curvy battery tray mod
I fitted a ZX10R rear shock to my dads bike recently, and because he's a bit of a perfectionist I didn't want to just shove some foam under the battery and wedge it against the seat, so made a new battery carrier:
Tray is made from cold rolled steel angle, courtesy of the robbing dogs at B&Q. It's a relatively thin gauge so it's pretty light and easy to weld. Needs sanding down and spraying or powder coating next. Battery strap is a universal item from eBay, they were either way too short or too long, hence the bottom mounting being under the battery to use up some length.
Tray is bolted onto tank bracket with a couple of captive bolts welded onto the tray.
Front of tray is supported by the tank bracket, the rear is bolted down through the back of the original battery tray.
Small alloy bracket to mount the fuses/relay onto.
Hopefully a fairly OEM look, the battery is nicely secure and the seat fits without touching anything.
Old 24-02-11, 11:17 PM   #2
loonytoon
Default Re: Curvy battery tray mod
nice job mate
Old 24-02-11, 11:21 PM   #3
beabert
I see someone else is making use of those b&q brackets. I used 3 on my diy tail tidy lol.
Old 24-02-11, 11:22 PM   #4
TamSV
TamSV's Avatar
Good work. Tidiest solution I've seen.
Old 24-02-11, 11:34 PM   #5
mikerj
Thank chaps. I agonised over chopping my old mans bike up for ages, but the original shock was very tired with 30k on it, and as I fitted cartridge emulators to the forks I wanted something decent at the back.
Old 25-02-11, 06:36 AM   #6
curvy custard
my battery rests on top of the zx6 shock reservoir, kind of wedged in there
Old 25-02-11, 09:12 AM   #7
Ricerocket
Nice work!
Old 25-02-11, 09:36 AM   #8
better than OEM
Old 25-02-11, 11:58 AM   #9
barwel1992
best battery mount i have seen on a curvy
Old 26-02-11, 08:55 AM   #10
curvy custard
Originally Posted by mikerj View Post
i had to cut the lower bit of tank bracket off on mine as it hit the reservoir
Battery Tray Fade Stuff Wanted 0 19-03-10 05:27 PM
under tray bod Stuff Wanted 0 02-01-08 08:32 AM
Under tray cuffy SV Ecosse 9 01-06-06 12:09 PM
Under Tray cuffy SV Talk, Tuning & Tweaking 12 19-04-06 11:46 AM
Under tray Natasha SV Talk, Tuning & Tweaking 2 01-04-05 09:05 PM
