Old 01-03-11, 01:57 PM   #1
timclarke1
Default Unrestricted ECU for '02?
have just dropped bike off at dealers for service he says he thinks my bikes restricted and that if i want full power i need to buy a full power brain which is £650 he says it should have came with the bike ? is this rite
Old 01-03-11, 02:08 PM   #2
sath182
Default Re: 02 650s performance
Correct me if I'm wrong, but if you've got a curvy, then the restriction would be with the carbs not the ECU.
Old 01-03-11, 02:18 PM   #3
Not for an 02. The restriction on 99-02 carbed bikes is done either with washers or with different carb plungers (called piston valves in parts fiche).
Old 01-03-11, 02:23 PM   #4
timclarke1
a curvy ? not sure its an 02 650s k5 if that means much trying up up load pics but wont work the bike may have to go if i need another 600 odd quid to feel the benifit of it
Old 01-03-11, 02:35 PM   #5
Whyte25
Hi, If it`s your Blue one on your page then yes it`s a curvy... Where abouts are you based? someone on here may be able to help you out..
Rgds
Old 01-03-11, 02:43 PM   #6
Paul the 6th
Paul the 6th's Avatar
just incase anyone else comes along and asks this, we now have pichers
SV650 (other known aliases: SV650 Naked or SVN) - available in both curvy and pointy guises the naked doesn't have an upper fairing but instead has a retro looking headlight - to differentiate between the two, look at the frame and style of the tail...
SV650S "Curvy" - manufactured 1999 to 2002, also known as a "curvy" or a "Curvy S"
SV650S "Pointy" - Manufactured 2003-2009, this is the pointy "S"
SV650 Sport - Manufactured 2006-2009 (they only introduced the "sport" version in 2006 if i remember correctly?), this is the same as the "pointy s" but has a lower fairing and a plastic seat "Cowl" where the pillion seat should be (along with the grab rail removed, and clever little "infills" to fill the gaps....). No mechanical difference between the sport and the "pointy s", just a bit of plastic
Note: Pointy lowers will fit any pointy (2003 to 2009)... You can also get lowers for curvys & same rule applies)
Hope this helps
posted by me ages ago
Old 01-03-11, 03:10 PM   #7
mikerj
It's can't be an 02 bike and a K5, the numbers are not compatible. A K5 would be a 2005 bike with fuel injection and could have a 33bhp ECU fitted. An '02 would be on carbs which have modified internal parts fitted to reduce power.
Old 01-03-11, 03:32 PM   #8
Unless someone has transferred a cherished 02 plate to it.
You don't need to spend £600 anyway if it is ECU restricted, just get a £50 secondhand ECU from ebay.
Old 01-03-11, 04:02 PM   #9
Owenski
either way the dealers trying to take your hard earned! collect the bike and slap the dealer, then name and shame them on here.
Old 01-03-11, 04:29 PM   #10
davepreston
fecking right name and shame thats new engine money that
Restricted vs. Unrestricted? XmisterIS SV Talk, Tuning & Tweaking 3 10-05-10 11:14 PM
unrestricted ECU 07+ edvin Stuff Wanted 0 12-07-09 12:45 PM
Unrestricted ecu for sale olden mgroin For Sale - SV's and SV related items 0 25-04-09 08:52 PM
now unrestricted - whoohoo ( my little write up) james160987 Bikes - Talk & Issues 4 16-04-07 11:43 PM
First big ride on unrestricted SV650 SVeeedy Gonzales SV Talk, Tuning & Tweaking 24 08-08-05 03:07 PM
