Old 02-03-11, 06:24 PM   #1
bikerskez
Default Coolant change, question about header tank.
Evenning all,
Firstly i have done a search and can't find what i'm looking for. I'm changing the coolant, i've removed the the filler cap, removed the drain plug and header bottle top, drained the coolant and flushed through. the header bottle is still full of old coolant. What am i doing wrong?
Old 02-03-11, 06:38 PM   #2
embee
embee's Avatar
Default Re: Coolant change, question about header tank.
Nothing.
To drain the bottle remove the small hose at the rad cap housing and lower it down, the bottle will empty out through this.
This small hose goes to the bottom of the bottle so that it will always take liquid back into the rad system when it all cools down and contracts, but any gas gets vented up through the liquid to the top of the bottle so is purged from the system, thus keeping it full of liquid as much as possible.
Old 02-03-11, 06:42 PM   #3
bikerskez
Thanks for the reply, i'll have a look tomorrow, one other thing, i started to refill it before i notice that the header tank was still full, question, will i lose what i have already put in?
Old 02-03-11, 09:56 PM   #4
embee
embee's Avatar
Shouldn't do, the only thing which connects the radiator/engine coolant circuit to the bottle is that small hose, and because it connects at the filler cap neck, you won't lose any coolant from the rad side when you take it off, you'll only drain the bottle.
Make sure it is reconnected afterwards!!
Old 03-03-11, 06:21 PM   #5
bikerskez
Embee, Thank you, i've now sorted it, simple when you know where to look, thanks again.
Regards Skez
Coolant flush/change? Jordy SV Talk, Tuning & Tweaking 8 11-02-11 10:06 PM
coolant change steveg SV Talk, Tuning & Tweaking 2 24-05-08 07:50 PM
Coolant change needed?? Al_Sweetman SV Talk, Tuning & Tweaking 4 15-11-07 02:08 PM
Header tank ARRGH riktherider SV Talk, Tuning & Tweaking 0 14-12-06 09:48 AM
Coolant Change TSM SV Talk, Tuning & Tweaking 6 30-06-05 09:11 AM
