Old 02-03-11, 10:54 PM   #1
Shaun.
Default Tail tidy, high level exhaust and indicators - problem?
Im buying a tail tidy for my sv, however im thinking the exhaust might by in the way of the indicator.
Whats your thoughts and is there a way round it if its a problem?
Im buying mini indicaters for the tail tidy.
Thanks
Old 02-03-11, 11:01 PM   #2
Default Re: Do i have a problem?
Doesn't look like the indi will fit in there with that big plate. And if it does it will be a bit hidden by the can.
Stubby the can or get an undertray with built-in indi's
Old 03-03-11, 05:33 AM   #3
SoulKiss
SoulKiss's Avatar
Most of which are illegal due to the requirement for a certain minimum spacing of indicators...
Old 03-03-11, 07:04 AM   #4
davepreston
have a ^ shaped bracket coming from the tail tidy to bottom of numberplate (behind out of sight) and mount the indies at the bottom left and right of the plate
Old 03-03-11, 11:01 AM   #5
SVMAT
Sorry to hijack the thread but does this mean indicators built in the rear light are illigal?
Old 03-03-11, 11:19 AM   #6
SoulKiss
SoulKiss's Avatar
Yep they are - as well as usually useless to the person behind you.
Most of them are not very bright and the colouration in certain light conditions can make the brake light and indicator look very similar.
From the VOSA pdf
Front indicator
Amber
2 max
Min height 350mm
Max height 1200mm
Min distance apart 240mm
Rear indicator
Amber
2 or 4 max
Height as front
Min distance apart 180mm
Max 300mm from rear
Old 03-03-11, 11:22 AM   #7
barwel1992
From the VOSA pdf
Front indicator
Amber
2 max
Min height 350mm
Max height 1200mm
Rear indicator
Amber
2 or 4 max
Height as front
Max 300mm from rear
my under tray and indicators are legal then
Old 03-03-11, 11:42 AM   #8
SoulKiss
SoulKiss's Avatar
Good for you
Many are not
Question is, are they effective?
Old 03-03-11, 11:53 AM   #9
barwel1992
Good for you
Many are not
erm there ok ish ...... but thats because i have a small plate and stubby (high level) exhaust
the new version comes with led's pretty sure that would be much brighter
Old 03-03-11, 11:57 AM   #10
Owenski
On that logic indies on mirrors are illegal (over 1200mm high).
Also mine must be illegal as I've 4 front indicators, 2 on the mirrors and 2 side repeaters.
As for the OP, EDIT: just seen the side view pic you posted. You'd be better off measureing it first cos yes, its going to be bloody close.
Problem With Custom Tail Tidy andyharding SV Talk, Tuning & Tweaking 40 05-03-10 12:36 PM
Fitting an Evotech Tail Tidy (normal indicators) disco SV Talk, Tuning & Tweaking 9 05-01-10 11:16 PM
high pipe and tail tidy, potential probs??? eano2 SV Talk, Tuning & Tweaking 3 14-08-07 01:20 AM
Exhaust, High level or not to high level..? Horney SV Talk, Tuning & Tweaking 5 06-10-06 03:54 PM
Tail tidies and high level exhaust diamond Bikes - Talk & Issues 5 25-06-05 06:44 PM
