Old 05-03-11, 08:27 PM   #1
muzikill
muzikill's Avatar
Default K3 engine fix - replace piston rings?
The bike went crunch at around 16k miles is it worth replacing them?
I'm just about to start building it all back up, all the greases and oils are there, gaskets waiting and engine bolts from chewie.
Old 05-03-11, 10:30 PM   #2
rictus01
rictus01's Avatar
Default Re: K3 engine fix - replace piston rings
I'm not sure I understand what you're asking here?
are you asking if you should replace them as a matter of routine ?
is there anything wrong with the rings or bores ?
under normal use piston rings should be good for a a lot more than 16k, so what makes you think you should replace them ?
Old 06-03-11, 08:51 AM   #3
muzikill
muzikill's Avatar
Partly routine and partly because the pistons are out anyways . . But i suppose im thinking too much into it and just adding a unecessary extra expense
Old 06-03-11, 09:18 AM   #4
mikerj
If the pistons are out then measure the ring gaps and you'll get an idea of how worn the rings and bore are.
Old 06-03-11, 09:43 PM   #5
muzikill
muzikill's Avatar
Rings measured and are out, replace! - dang - £90!
16k mile bike , mind you i was wondering if my measurements are out.... for a start the rings are covered a wee bit in carbon/oil gunk so that might be making the measurement go out, plus when the engine is rebuilt wont it compress the gap back in to normal?
Front piston, Thickness, 1st 1,21mm 2nd 1.1. End gap 1st 8.76mm 2nd 10.63mm
Rear piston, Thickness 1st 1.26mm 2nd in spec. End gap 1st 8.60mm 2nd 10.00mm
I noticed the rings are very loose in the piston grooves due to being gunked up.
Old 06-03-11, 10:07 PM   #6
If it had plenty compression before why replace them?
measure end gap with them in bore
Old 06-03-11, 10:37 PM   #7
muzikill
muzikill's Avatar
Yup, a 16k bike that needs the rings replaced? - it's because the manual says its 'good practice' to replace them.
btw what does 'in bore' mean?
Old 06-03-11, 10:44 PM   #8
Put them in the cylinder.
Make sure they are level/perpendicular with bore within .5mm or less and measure at 3 places, top, middle and bottom.
Old 06-03-11, 11:29 PM   #9
mikerj
If the bikes been looked after (e.g. regular oil changes) then 16k's worth of wear should be pretty insignificant. Plenty of SV's with 3 times that mileage on the original engine.
Old 06-03-11, 11:37 PM   #10
barwel1992
£90 ? cost me £100 for 2x head gaskets 2x base gaskets 2 sets of piston rings from the us INC P&P genuine suzuki parts
running new piston rings and bores in ? barwel1992 SV Talk, Tuning & Tweaking 21 24-01-11 03:52 PM
Piston rings - where from? barwel1992 SV Talk, Tuning & Tweaking 4 05-12-10 01:22 AM
Engagement rings Daimo Idle Banter 60 09-03-09 08:30 PM
Bored of the rings? Jester666 Idle Banter 5 15-09-06 10:16 AM
Wedding rings.... DanAbnormal Idle Banter 24 03-08-06 09:01 PM
