Hardware Post your own reviews, opinions and experiences on this subject.
Old 06-03-11, 08:46 PM   #1
muzikill
muzikill's Avatar
Default Sv650s K3 -Full gasket set.
Since i bought one of these i thought i would post a few pics to let you see what you get for your dosh! - i bought it for £86.83 (bike of the month) usual rrp 139.74
The photo above shows you where the smaller gaskets go...
Old 06-03-11, 09:34 PM   #2
muzikill
muzikill's Avatar
Default Re: Sv650s K3 -Full gasket set.
Well, unless you know where else to get them your kinda stuck with one place.
The pics 2&3 are the gaskets for the rotor and the clutch are the 'paper' type. I tried to scan them but the clutch one is too big and the rotor one when printed out doesnt match the original size. Because the gasket paper is cheap to buy i thought a stencil for people to print off would be a good thing.
I noticed the gaskets that came off between the cylinder head and the crankcase (pic 4) were fine without much damage and probably re-usable (they are metal and embossed around the holes).
The gaskets in pic 5 are the ones that sit between the cylinder head and valve head (each one comprises of copper gasket sealed between 2 thin metal gaskets, again embossed around the holes if fits around). I can't see anyone removing these and reusing them. That area has too much heat, petrol, gasses & cooling going on. Even though they are metal you still have to 'peel' them off a bit.
The gaskets in pic 6 are for the cylinder heads, if your careful when you remove the covers you can leave them be (also doing clearance checks) you shouldnt need to replace them.
The gaskets for the clutch and rotor are the 'paper' type. I tried to scan them but the clutch one is too big and the rotor one when printed out doesnt match the original size. Because the gasket paper is cheap to buy i thought a stencil for people to print off would be a good thing.
The 2nd last pic is a load of seals, a couple of gaskets etc. Only of use if you are splitting the engine which means you would remove the exhaust and heads.
So, you couldnt reclaim the gaskets in pic 2,3 & 5.
You might be ok with 4.
Pic 6 in most cases if you take your time it will be fine.
The final pic with the seals it depends on what job you doing, the two gaskets to the bottom would only be needed if you doing 'bigger' jobs.
Old 06-03-11, 10:09 PM   #3
punyXpress
punyXpress's Avatar
" The gaskets for the clutch and rotor are the 'paper' type. I tried to scan them but the clutch one is too big and the rotor one when printed out doesnt match the original size. Because the gasket paper is cheap to buy i thought a stencil for people to print off would be a good thing. "
If you scan them & peeps photocopy them, be careful - one axis of the copier may distort. Very noticeable with o.s. map copies.
Now: Street Triple R
FS: SK1 SV650s, Full Fairing + Extras, 18.6K Miles Fade For Sale - SV's and SV related items 5 02-05-11 10:00 PM
How easy is to add full fairing to SV650S Pointy? Maverick9999 SV Talk, Tuning & Tweaking 7 12-02-10 05:12 PM
sv650s K7 full lower fairings JimmyG SV Talk, Tuning & Tweaking 3 30-03-08 01:13 PM
SV650S Full Fairing Maestro SV Talk, Tuning & Tweaking 4 28-12-06 01:06 PM
Will full lowers for sv650s fit sv1000s ? Dimitris SV Talk, Tuning & Tweaking 3 18-09-04 06:41 PM
