Old 08-03-11, 08:50 PM   #1
davepreston
Default SV1000 belly pan bracket dimensions?
id appreciate dimentions and a photo or two of the belly pan brackets for a sv thou please people
dave
Old 09-03-11, 07:16 AM   #2
21QUEST
21QUEST's Avatar
Default Re: SV1000 belly pan bracket dimensions?
DP
Is it the faired SV1000 belly pan(S and N ar different design) you are looking to put on? Or have you got some sekrit belly pan plan going on lol.
Asking as I've sure I've got a set of brand new brackets that were needed for putting the faired belly pan on the naked SV1000.
Give us a shout bud if that would suit your requirements.
Nemo me impune lacessit.
Old 09-03-11, 04:30 PM   #3
davepreston
SOULKISS was it a s or n belly pan you gave me
whats the differance by the way ben, if required i could basterdise it possibly, pm me wuth how much you want for it mate
Old 10-03-11, 07:09 AM   #4
21QUEST
21QUEST's Avatar
DP
located the brackets(3) which I think are all that were required. I shall double check and confirm.
Emmm couldn't really describe the differences lol but certainly had different mounting points. The one you had off SK if off an SV1000 would almost certainly be off a faired, as the ones for teh naked were VERY expensive, hence folks sourcing the ones off the faired and making it fit
PM me your address anyway as very busy at moment so can just pop in post if I get free time before Saturday.
Off hand, I'd say £20 delivered. Anyhoos, price would be 'right' for you mate, so we'd not worry about that
Old 10-03-11, 07:22 AM   #5
SoulKiss
SoulKiss's Avatar
No idea, I ordered it from SvSpares as an SV650 one, and then realised the mistake 4 months later when I went to try and fit it, which was too late to get swapped/changed.
There are some numbers stamped on the insideon the bottom, near the nose - one of those will be a part number I am sure.
Curvy lower fairing bracket dimensions? bhp.on.tap SV Talk, Tuning & Tweaking 6 18-12-10 09:34 AM
Pointy belly pan/lower fairing fitting kit - dimensions please .aj. Bikes - Talk & Issues 0 02-09-10 07:44 AM
Fairing lowers, rear bracket dimensions please. el berto SV Talk, Tuning & Tweaking 0 12-07-10 09:56 AM
Pointy belly-pan bracket dimensions please. dave SV Talk, Tuning & Tweaking 7 29-11-09 05:34 PM
SV1000 Dimensions Needsy SV Talk, Tuning & Tweaking 2 12-02-09 09:04 PM
