Old 09-03-11, 02:16 PM   #1
JeffF
Default Oil Change - Now Won't Start.
The bike is a 2005 pointy SV650.
I've just changed oil and filter at 8000 miles and ... the fuel pump whirs, the engine spins when I press the button but there's no sign of it firing! I can smell petrol after it's turned over for a while and I've left it in case I've flooded it somehow.
I've checked the kill switch is in the right position and I'm stumped about what I've disturbed that would prevent the bike from running.
Before I start taking things apart, is there anything I'm likely to have messed up?
Thanks
Jeff
Old 09-03-11, 02:28 PM   #2
Viney
Default Re: Oil Change - Now Wont Start
How much oil did you put in?
Old 09-03-11, 02:34 PM   #3
454697819
is it on a centre / paddock stand and is the side stand down?
Old 09-03-11, 02:45 PM   #4
JeffF
Thanks for the quick replies!
Oil - I've put about 2.5 litres in. Was going to run the engine for a minute then check the level and top it up.
Stand - I'm holding it upright with the side stand up (Sadly my paddock stands are in the garage with another broken bike)
Old 09-03-11, 02:57 PM   #5
Rai86
Sounds like you may of disturbed the coil wire or the pickup
Have you tank off or not?
Old 09-03-11, 03:11 PM   #6
JeffF
No, just oil drain plug, filler and the filter.
I have just taken the pillion seat off and checked the fuses there - all ok.
Old 09-03-11, 03:20 PM   #7
Rai86
thats well odd then, sounds flooded.. trying spinning it over on full throttle
Old 09-03-11, 03:27 PM   #8
Paul the 6th
Paul the 6th's Avatar
if it's flooded do ya not just spin it over without any throttle so the engine turns and doesn't get any more fuel? Or have I got it the wrong way round
Old 09-03-11, 03:35 PM   #9
Rai86
You need the extra air to try and clear it - its what i do, it should slowly try and catch if its that, or he could pull out front plug and see if its wet, if it is leave it to air then hopefully it will catch on that 1
Old 09-03-11, 04:09 PM   #10
Paul the 6th
fair play. I remember at cadwell when irsky dan was trying to start a cbr600 which should have been broken & sold for parts a long time ago. He managed to get it started but with the throttle pinned fully open it just stuttered constantly at about 2k revs.
I told him to let go of the throttle and hold the starter til it started to tick over normally on its own. Problem solved. Then he tried to rev it.... screaming clutch anywhere above 4k rpm lol. It stayed in the van that day!
Is there any chance the OP has left the bike in gear and the sidestand switch has failed maybe?
Spend £117 & change on bike - but no change in bike pete m Bikes - Talk & Issues 10 06-05-09 12:26 PM
Wont start, but will bump start :( Wally SV Talk, Tuning & Tweaking 6 10-08-07 02:02 PM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
Oil Filter Change with every oil change? Ceri JC SV Talk, Tuning & Tweaking 2 22-11-04 06:02 PM
