Old 09-03-11, 03:15 PM   #1
Viney
Default Is it...
...Triple or Treble when referring to 3 of something?
Old 09-03-11, 03:19 PM   #2
Paul the 6th
Paul the 6th's Avatar
Default Re: Is it...
is it triple when referring to a collective i.e. triple cylinder....
and then treble when referring to an effect i.e. the volume is trebled...
but then volume can be tripled - doesn't sound lexically correct?
is it too early to throw 'trio' into the mix?
Old 09-03-11, 03:20 PM   #3
Owenski
triple if its accountable
treble if its acumulative
or something like that.
Old 09-03-11, 03:24 PM   #4
Paul the 6th
just us 3 on the org at the mo then?
like a menage a ****.
Old 09-03-11, 03:38 PM   #5
Viney
So would it be Triple 4 or Treble 4 if referring to a phone number?
Old 09-03-11, 03:59 PM   #6
Quedos
Triple 4 to be grammatically correct.
Old 09-03-11, 04:04 PM   #7
Paul the 6th
no it would be
"oh seven wun four four four six three too ate nein"
if you were scottish. Otherwise triple 4 is fine.
Old 09-03-11, 04:06 PM   #8
allantheboss
Somebody describe the difference between "who" and "whom" as simply as possible
Old 09-03-11, 04:10 PM   #9
Paul the 6th
well who is indefinite but whom is trying to apply it to someone without knowing who it is I guess?
To who? sounds like a question
To whom sounds like it's addressed to somebody but none of us are quite sure whom it should be addressed to...
Old 09-03-11, 04:19 PM   #10
benji106
if you can re-arrange the sentence and put a subject pronoun (I or he) instead of who/whom you should use 'who'. If you can put an object pronoun (me, him) instead of who/whom, you should use 'whom'.
