Old 10-03-11, 01:03 AM   #1
monkey
Default What is the best product to clean and then protect electrical connections?
Is a little ACF50 followed by vaseline going to work as well as contact cleaner followed by dielectric grease?
Thanks.
Old 10-03-11, 09:29 AM   #2
Default Re: What is the best product to clean and then protect electrical connections?
Yes that'll do the trick
Old 10-03-11, 09:39 AM   #3
AndyBrad
i didnt think acf50 was a cleaner?
Old 10-03-11, 09:45 AM   #4
It's not but all you're "cleaning" is scratching the corrosion off the surface, and the ACF will creep into the crimped bit behind the connector and protect that better than vaseline alone. Only needs a drop.
You can use contact cleaner or WD first if you want.
Old 10-03-11, 11:27 AM   #5
monkey
Thanks. Short and sweet like a chocolate midget.
Old 10-03-11, 12:33 PM   #6
mikerj
I use Contralube 770 on all the connectors of my bikes. Maplin sells it, or can be had from various eBay sellers.
Old 10-03-11, 09:30 PM   #7
thefallenangel
Contact cleaner is the best. Need some on mine tbh.
Old 11-03-11, 03:07 PM   #8
Radlad
ACF50 works fine for me.
Ring Terminals - battery connections. 5hort5 SV Talk, Tuning & Tweaking 5 04-03-10 04:34 PM
Corroded connections Razor SV Talk, Tuning & Tweaking 6 16-08-09 08:03 PM
Paypal don't protect ya Shellywoozle Idle Banter 28 22-09-08 03:45 PM
Oil Cooler Connections buckstone SV Talk, Tuning & Tweaking 5 17-03-07 09:33 PM
Yer Ears!! Protect 'em! Jester666 Bikes - Talk & Issues 17 24-07-06 03:02 PM
