Old 13-03-11, 10:17 PM   #1
Foamer
Default Generator windings
Generator windings needed for K1 curvy.
Old 13-03-11, 10:49 PM   #2
Default Re: Generator windings
I've got some, sorry forgot to say in other thread.
Comes with pulse coil and that moulded bit you were worried about all as one unit.
Old 13-03-11, 10:53 PM   #3
Foamer
Thats champion, how much would it be, where are you.
I will confess, I jumped in and changed the reg/rec for a new one, the original may be ok if you want it.
Old 13-03-11, 11:01 PM   #4
Not worth the risk, quite plausible for a buggered reg rec to fry the generator.
I'm in Halifax, £30 + P+P unless you want to collect, will test it tomorrow.
Old 13-03-11, 11:03 PM   #5
Foamer
That was my next question, could another underlying fault cause one of the 18 windings to go bang ?
Old 13-03-11, 11:05 PM   #6
Overcurrent from a dodgy reg rec causes heat build up which will find weakest point in insulation and arc that bit out. Or it was failure of insulation which spread out.
Personally I would change reg-rec for a newer MOSFET one just for reliability.
Old 13-03-11, 11:11 PM   #7
Foamer
Have PM'd you my Tel No. £30 is smashin.
Honda Generator £150 disco For Sale - Other Bikes and General biking items 14 10-05-10 09:29 PM
generator covers rude SV Talk, Tuning & Tweaking 4 08-12-08 05:38 PM
Box Trailer + Generator Olly For Sale - SV's and SV related items 0 06-10-08 02:24 PM
Rave Generator! Skip Idle Banter 5 15-01-08 04:25 PM
how to check the generator mart SV Talk, Tuning & Tweaking 0 12-05-07 11:07 AM
