Old 15-03-11, 12:23 PM   #1
Lego
Default Datatool Alarm System 3 problems
Motorbike battery lost all charge, so I replaced it on doing so the alarm system sounded but could not be reset with the key fob (fobs battery ok)
Any suggestions?
Thankyou
Lego
Old 15-03-11, 05:12 PM   #2
davepreston
Default Re: Datatool Alarm System 3 problems
you can use the pin number on the other box (you need the pin and instructions) and its a pain in the **** to do
Old 15-03-11, 11:42 PM   #3
Lego
I got the pin No but no instructions and no other details with the system... I got a receipt which shows the name of the alarm system and has "fuel pump fuse" written on it in pen and then signed by the installer
Although I did find instructions on the Datatool site, it does look a pain in the **** lol! Where would the digits show? Is it on the speedo? Also... What you mean by the other box?
Old 16-03-11, 01:06 AM   #4
monkey
If you read the instructions you will see the digits don't show anywhere but the pin 'numbers' are an amount of beeps.
I'd suggest following the de-spiking instructions if the pin doesn't work.
The receipt you mentioned suggests to me the installer has used the fuse for the fuel pump to also feed the alarm.
In the future you really need to set the alarm in service mode before you remove a battery. If the bleep every 15 seconds annoys you the siren can be unplugged.
I've got no idea what Dave is talking about with the other box.
Old 16-03-11, 06:46 AM   #5
davepreston
iirc there are 2 boxs, on trigger box (towards the front) one noise box (on the rear)
Old 16-03-11, 10:24 AM   #6
Lego
Just got off the phone with Datatool their first suggestion was to check the motorbikes battery, but after I turned the ignition on and the speedo screen didn't work they think its a problem with the bike as this should never happen.
Checked the battery anyway and its at 8.8v
Why didn't I check the battery? Even though it's a new one "ready to go" lol
Thanks for your help guys, just downloaded the manual for the alarm, incase any further problems occur...
Fingers crossed it was just the battery
Old 16-03-11, 11:49 AM   #7
monkey
8.8v?! That could be knackered. It's certainly not ready to go.
Old 16-03-11, 01:00 PM   #8
toxic
Charge the battery. How long did you leave it after you put the acid in it?
Old 16-03-11, 01:03 PM   #9
Lego
Was a new battery, bloke behind the counter said fully charged ready to go lol, so on charge now 'til I get home from work
Old 16-03-11, 01:05 PM   #10
toxic
That's strange, when I buy a new battery there's no acid in it. Usually I have to put the acid in myself and then the battery is new and ready to go, but I wait an hour, letting the chemical reaction settle down a bit...
Unless the bloke had only just filled the battery, then it could have been sitting for ages. Where did you get it?
DataTool System 3 Problems squirrel_hunter SV Talk, Tuning & Tweaking 9 25-04-08 08:39 PM
Datatool System 3 Alarm - Help please Matt Prince SV Talk, Tuning & Tweaking 6 04-12-07 03:12 PM
Datatool System 3 Alarm Woes I'm_a_Newbie Bikes - Talk & Issues 1 02-11-07 02:59 PM
Datatool System 4 Alarm/Imobiliser DarrenSV650S Bikes - Talk & Issues 1 16-09-06 01:39 PM
Datatool System 3 Alarm in Curvy SV650S Wiring Loom Ter For Sale - SV's and SV related items 7 22-05-06 01:55 PM
