Old 17-03-11, 11:02 PM   #1
LJH
Default Curvy shorter front springs?
I'm thinking about getting Sonic 0.85kg/mm front springs with 15w oil but can you get slightly shorter ones, not much maybe -20mm?
Old 17-03-11, 11:08 PM   #2
jambo
jambo's Avatar
Default Re: Curvy shorter front springs?
The question you're asking is perhaps not quite the right one:
You can have a shorter spring and a longer spacer, or a longer spring and shorter spacer. However, if you were to have a 20mm gap at the top of the spring before the fork cap you'd create a fork that was at best horrible, and quite possibly dangerous.
If you wanted to change the geometry, you can adjust the forks up through the yokes by ~10mm without any clearance issues, but that's about as far as you can go.
Jambo
Old 17-03-11, 11:21 PM   #3
LJH
Yeah a spacer would be put in to take up the space.
oops was getting confused with cars , so the yokes is the only way, I just think it looks too high at the front and I want better turn in by lowering it.
Old 18-03-11, 11:56 AM   #4
daveyrach
Mine have been put thru the yokes, see link:
http://forums.sv650.org/showthread.php?t=163162
I bought it like this and personally don't like it, am looking at raising it back up.
Old 18-03-11, 04:57 PM   #5
LJH
Oh yeah, how many mm was it from the top?
Also does anyone know the colour of the standard rear spring? Mine is yellow and was thinking it might be different.
Old 18-03-11, 05:25 PM   #6
daveyrach
Its around 15-20mm it doesn't foul on the mudguard either.
Old 18-03-11, 05:46 PM   #7
mikerj
The curvy has a yellow spring, pointy has a white one.
BTW, putting a shorter spring in the forks and then adding longer spacer is going to put you back to the same starting point.
Old 18-03-11, 06:01 PM   #8
toxic
If you want better turn in, raise the rear. Unless you're a bit short?
Old 18-03-11, 06:40 PM   #9
barwel1992
or do both
(higher rear, lower front)
Old 18-03-11, 06:44 PM   #10
toxic
I'm against lowering the front, ground clearance can become an issue unless you have higher pegs fitted.
Front Springs - YET again. DANINPLYMOUTH SV Talk, Tuning & Tweaking 82 23-06-09 02:23 PM
curvy aftermarket front springs (hagon, Ohlins, etc) stuballs Stuff Wanted 9 30-12-08 12:37 AM
Standard front fork springs for a curvy Paul M For Sale - SV's and SV related items 4 02-10-07 10:18 PM
Shorter dogbones to raise curvy rear end andyb SV Talk, Tuning & Tweaking 12 08-12-06 02:10 PM
Will SK1 front fork springs fit a curvy? streetos SV Talk, Tuning & Tweaking 3 17-06-05 02:48 PM
