Old 19-03-11, 06:24 PM   #1
muzikill
muzikill's Avatar
Default Cam chain tensioner bolt sheared.
As you know i am in the middle of re-building my engine ........
Oh bugger!!
Old 19-03-11, 06:28 PM   #2
Default Re: Cam chain tensioner bolt sheared -boll*cks!
I agree with the above summation.
If it sheared on fitting it then an easy-out may actually work.
Old 19-03-11, 06:38 PM   #3
muzikill
muzikill's Avatar
Dunno wether to do it myself or chuck it into a garage, ive got the two sheared bolts from the front cylinder exhaust head to get removed... not worth the hastle ..... been reading not to buy a cheap easy out ... you know the difference?
Edit: found this too
http://www.youtube.com/watch?v=4wNhV...eature=related
Old 19-03-11, 06:44 PM   #4
Buy some that have dormer or presto on the box.
Old 19-03-11, 07:15 PM   #5
muzikill
muzikill's Avatar
Thanks mate! - i'm almost there
Sheared radiator bolt. larigos SV Talk, Tuning & Tweaking 14 07-09-11 12:38 PM
Sheared Engine Bolt. Sideshow#36 SV Talk, Tuning & Tweaking 7 29-05-09 08:31 PM
Cam chain tensioner bolt adjuster thingy me bob jumjum_0214 SV Talk, Tuning & Tweaking 22 05-11-08 03:13 PM
Sheared Bolt - need help DarrenSV650S Bikes - Talk & Issues 33 28-12-06 10:03 PM
Sheared radiator bolt? Sponge SV Talk, Tuning & Tweaking 2 10-01-05 11:17 PM
