Well got this in Novermber or something last year with 14k miles on it...
![]() ![]() ![]() Mods are:- Viper exhaust black double bubble screen Pyramid belly pan de-grab railed tail tidy Alpha dotted Rear hugger Rear undertray So far just gave it a service... ![]() Filled with Motul 7100... ![]() Changed plugs. ![]() Have now stripped it down, to paint it black and white (bmw saphire black and bmw alpine white). Prob take engine out and re-paint that black, but seen some special tool you need??? Did some stuff.... ![]() Plastic welded up a crack round the front right indicator... ![]() Sanded... ![]() Fillered.... ![]() High build primered some panels... Stay tuned ![]() |
There's an ebay seller that does the SV engine and swingarm tools. Well worth getting IMO if you're going to drop the engine.
Looking forward to progress. ![]() |
![]() ![]() Whitey goodness! |
Looking good. Your reg is only 14 away from my curvy that I got new from my local dealer in Southampton in 2000 - W674WBK
2000 - 2004 SV650S 2004 - 2009 SV1000S 2009 - 2013 Triumph Sprint ST1050 2013 - 2016 Triumph Explorer 1200 2016 - Ducati Multistrada DVT S ![]() |
Nice to see a curvy being looked after
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
Do you want to sort mine out after???
Did you use a soldering iron on the front fairing? Mine are both cracked and I'm looking at changing the colour of the whole bike from dull yellow (clearly some botched re-spray) to black in the near future. I need help. |
Indeed just used a soldering iron, was pretty easy. Just need to spead the plastic with the wider part of the iron don't go too fast as it won't do anything or too slow as to burn a hole in it but enough maybe 1-2mm penetration each side.
![]() ![]() Back middle panel lacquered... ![]() Took out 2nd and 3rd gear switch to ecu wires, mine was green/blue and red/black instead of red/yellow. Last edited by LJH; 30-03-11 at 11:35 PM. |
#9 |
#10 |
why did you remove those connections for ECU??? just wondering?
gsxr build | sv650nutter149 | Thames Valley | 21 | 12-05-10 07:22 AM |
StreetFighters Mag Curvy Build. | Nicky S | SV Talk, Tuning & Tweaking | 10 | 31-10-09 12:18 PM |
About to build one of these | SV-net | Idle Banter | 14 | 22-11-08 04:14 PM |
ANOTHER Rear Shock Thread (curvy) | phizog | SV Talk, Tuning & Tweaking | 21 | 19-12-07 09:42 AM |
Gixer front end on a curvy (last thread today I promise :) ) | MavUK | SV Talk, Tuning & Tweaking | 16 | 10-04-07 01:25 AM |
