Old 25-03-11, 12:38 AM   #1
Nobbylad
Nobbylad's Avatar
Default How do you balance the throttle bodies on a K8?
Haynes manual says you need a special Suzuki tool, is there another way?
Old 25-03-11, 12:53 AM   #2
rictus01
rictus01's Avatar
Default Re: How do you balance the throttle bodies on a K8?
yeah you can make a home balancer, plenty of examples on the net, but I wouldn't trust there accuracy, see if someone local has a set you can borrow for a beer or two.
Cheers Mark.
Old 25-03-11, 01:45 PM   #3
Nobbylad
Nobbylad's Avatar
Hmmm...manual says it needs to be done with the SDS (Suzuki Diagnostic Scanner) so that you can set the idle speed control (ISC) value between the two cylinders.
After some searching, you can get a tester that looks like it will do this for £140 here.
Is this techno tomfoolery or necessary kit?
Normally the dealer would do this as part of the servicing whenever they check the valves etc, however if you're doing servicing yourself, might be worth having?
Thoughts?
Old 25-03-11, 03:45 PM   #4
yes you do really need the gizmo box as you have to lock the throttle bodies and lock the rpm.
i tried to do it to my k8 without it and it made no bit of difference to the vacuum gauges. i also found out that you dont adjust the balance screw but adjust the 2 little air screws instead.
i think the box your looking at is a re branded chineese one that you can get direct for £90.
http://www.aliexpress.com/product-gs...olesalers.html
Old 25-03-11, 04:50 PM   #5
Nobbylad
Nobbylad's Avatar
Hmmm...58 squid delivered....that's not bad considering local dealer wants £60 to balance them
Old 25-03-11, 06:18 PM   #6
think i'll take a little gamble with one. forgot the price was in $$
Old 25-03-11, 07:31 PM   #7
Nobbylad
Nobbylad's Avatar
I just ordered one, they'll post Monday and said it would take 15 days. I'll report on here once it arrives.
Old 08-04-11, 08:35 PM   #8
Nobbylad
Nobbylad's Avatar
Oooh...my goodies have arrived...not bad considering I only ordered them less than 2 weeks ago!
Old 08-04-11, 09:15 PM   #9
Speedy
Have you tried it yet??
Seems like an interesting piece of kit!!
Old 08-04-11, 09:26 PM   #10
Nobbylad
Nobbylad's Avatar
Not yet, hopefully over the weekend
SV1000 throttle bodies on a 650? Weeble SV Talk, Tuning & Tweaking 33 11-12-09 11:04 PM
ANOTHER set of throttle bodies..? Please no... Bluewolf SV Talk, Tuning & Tweaking 6 08-06-09 09:28 PM
Removing throttle bodies muffles Bikes - Talk & Issues 4 19-04-09 12:50 AM
Pointy 650 throttle bodies svdemon For Sale - SV's and SV related items 2 15-04-09 02:49 PM
sync throttle bodies olden mgroin SV Talk, Tuning & Tweaking 5 29-09-08 07:41 PM
