Old 30-03-11, 01:22 PM   #1
Terah
Default Changes to Mod 1
Just seen the changes coming in for Mod 1. Notable one is that the emergency stop is before the avoidance exercise, and you can only do the avoidance if you have successfully done the e stop.
http://www.dft.gov.uk/dsa/News.asp?i...83A660&cat=593
Old 30-03-11, 07:04 PM   #2
Kenzie
Kenzie's Avatar
Default Re: Changes to Mod 1
Can't wrap my head around the new test stuff. I did mine in 2001 and it was cbt>theory>test which consisted of putting the bike on it's stand, a u-turn, an emergency stop, ride around the streets and a couple of questions!
Old 30-03-11, 07:29 PM   #3
ImplodedHamster
them changes look alot better actually, the first ride round the circuit for to familiarise yourself would be very helpful
Old 30-03-11, 10:14 PM   #4
Ed
Originally Posted by DSA website
For the high speed manoeuvres, DSA intends to introduce a degree of flexibility into the assessment of the speed requirement. There will be a five per cent tolerance of the speed required. (2 km/h below 50 km/h). Providing the candidate commits no faults other than not reaching the speed within this tolerance, the examiner should record this as a riding fault rather than a serious fault. (A riding fault will contribute to the result of the test. A serious fault would result in failure)
How do they know, do they use a speed gun?
The whole set of amends sounds very sensible to me.
Old 30-03-11, 10:25 PM   #5
orose
They do, as it happens...
I must admit, I do like that they've decoupled the swerve from the emergency stop, replacing the latter with a controlled stop (less precision required). It's also clear from the release why the DSA thought people were failing on that component...
Old 30-03-11, 10:25 PM   #6
pce13
You ride through a speed trap just before you do emergency stop and swerve
Old 30-03-11, 10:26 PM   #7
Terah
It's through a timing gate.
Having just done mod 1 recently, it all makes a lot of sense to me. I found the avoidance harder to do than the emergency stop, so I think it should be easier to do a gradual build up from controlled stop, to emergency stop, to avoidance.
Old 30-03-11, 11:13 PM   #8
Ed
I'd love to have a go, but only if the result don't count
Old 31-03-11, 05:55 AM   #9
Trouble is, indicated speed is higher than actual speed, do they tell you to compensate ?
Old 31-03-11, 06:31 AM   #10
orose
Before these changes, there was no leeway on the speed measurements... you had to be doing a minimum of 50 kph on their equipment, or you would be sent around for another go. If you were short again, you would fail (might have been if you're short 3 times). No provision was made for weather either.
