Old 07-04-11, 10:13 AM   #1
daveyrach
Default Curvy CCT's
Are the cam chains manually adjusted on the curvy or do they auto adjust themselves? If they are manually done can some explain how as there is no mention in the Haynes manual i have.
Old 07-04-11, 10:35 AM   #2
m`baubz
Default Re: Curvy CCT's
they're self-adjusting
Old 07-04-11, 11:07 AM   #3
daveyrach
If i replace them will this solve the annoying rattle
Old 07-04-11, 12:45 PM   #4
johnnyrod
johnnyrod's Avatar
Yeah the curvy ones are a bit crap, you can wind the engine backwards with a spanner (or bump it) and they shut up for a while. Fit the later ones, K3/K4, they go straight on but you need all the bits inc the end plug.
Old 07-04-11, 12:51 PM   #5
daveyrach
I'm intigued how does winding the engine backwards help? What exactly would i need to change em over?
Old 07-04-11, 04:35 PM   #6
mikerj
First I've heard of it.
Gynaecology skills would be useful, they are a bit tight to get to! You might try just removing the small bolt in the end of the tensioners and using a screwdriver to manually back them off a few times (by turning clockwise until it stop and then pulling screwdriver out) to ensure they are free. Obviously replace the bolt afterwards.
If you have to change them they are held in with cap head bolts (5mm I think), and you get to the front cylinder by raising or removing the fuel tank. I found the only way to get to the rear one was using a long extension and a universal joint, to go up past the rear shock.
Old 07-04-11, 05:42 PM   #7
I find rear dead easy, just whip RHS rearset off and you can even see it!
The rattle is pretty much par for the course and not detrimental.
Old 07-04-11, 06:22 PM   #8
daveyrach
Just seems to get louder, strange thing is sometimes it really bad and sounds terrible and other times not there at all! Like Monday my 12 mile morning commute it didn't rattle at all but today on my way home it sounded awful
Old 07-04-11, 08:06 PM   #9
Mykey.M
how does your rattle happen?
i get one when im just about to stop and pull the clutch in, n it only happens when the revs drop fast.
i took my tensioner out today and now i cant get it back in without it popping back out of it self! so i may have to drop the engine
Old 07-04-11, 10:11 PM   #10
No you need locking tool
Speedo from a curvy S fit into a curvy Naked housing? Taipan SV Talk, Tuning & Tweaking 6 18-02-10 04:59 PM
CCT's wanted 5tu Stuff Wanted 4 24-02-09 11:08 PM
Naked Curvy Bottom yoke and Curvy speedo drive 21QUEST Stuff Wanted 6 29-01-09 09:36 AM
thought i best post some here, curvy lowers on my curvy BIKER-DENE Photos 3 06-05-06 07:26 AM
